Re: [cgal-discuss] Intersect lines with lines, and, polygons with polygons in 3D space
- To: <>
- Subject: Re: [cgal-discuss] Intersect lines with lines, and, polygons with polygons in 3D space
- Date: Fri, 13 Nov 2015 11:12:00 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:KxBpDxIHXikEYM5q3tmcpTZWNBhigK39O0sv0rFitYgUIvnxwZ3uMQTl6Ol3ixeRBMOAu68C1rOd6/GocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0oLqjqvqqtX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86FpyshbTK+vf7gkVacKS3M9ImUt7YvqswPCRE2B/DwHQ2AOm11JBQbCqxr1V5O0virhvfdmw3qmOpiiRr89XXGu7rxgVQTzoCYBLT8wtm/N3J9elqVe9RKmugdkzoicNIGSKeFlc6X1fMsVXSxPRJACBGR6HoqgYt5XXKI6NuFCotylqg==
OK, so computing intersections directly is too complex to be realistic.
A way to do it would be to : compute closest distance, then project closest point (of line / polygon) on the line / polygon to intersect, right ?
Still need to check / understand if CGAL provides operators to compute closest distance and orthogonal projections: if somebody has some clue about that, I would appreciate to let me know.
Franck
Le 2015-11-13 3:22, zell_winston a écrit :
Hi houssen,
As far as my knowledge goes, geometric libraries dont usually provide
the "Intersection of a pair of 3D lines". This is because the high
possibility that 3D lines are not intersected at all.
Instead, in computational geometry theory, we usually discuss the
closest distance between two 3D lines. If the distance is smaller than
your predefined tolerance, you can assume it to be intersected.
I haven't check the CGAL context for detail. Hope this quick message
will help you.
zell_winston
DATE: 2015-11-13 01:38
TO:
[2]
SUBJECT: [cgal-discuss] Intersect lines with lines, and, polygons
Hello,
I need to intersect polygons, or lines, made of 3D points : is this
possible with CGAL ?
I am new to CGAL.
First, I checked out the doc to intersect polygons, or lines, made
of
2D points (x, y):
http://doc.cgal.org/latest/Sweep_line_2/index.html
http://doc.cgal.org/latest/Boolean_set_operations_2/index.html (in
particular section 3.3)
I went accross the tutorials without any problem using Point_2,
Segment_2 and Polygon_2.
Then, I looked at the doc related to using 3D points instead of 2D
points (http://doc.cgal.org/latest/Polygon/index.html - section
2.3): it
seems at least some operations are possible (for example,
is_simple).
Now, I try to turn my basic tutorial into 3D space : basically, I
tried
to replace Point_2 by Point_3, Segment_2 by Segment_3, Polygon_2 by
Polygon_3 the "naive" way, this seems not to be possible.
CGAL::compute_subcurves turns out to be unable to support
Segment_3,
right ? Also Polygon_3 does not seem to exist ! :D
Can I compute intersections of polygons, or lines, made of 3D
points
(x, y, z) with CGAL ?
Franck
Links:
[1]
mailto:
[2]
mailto:
- [cgal-discuss] Intersect lines with lines, and, polygons with polygons in 3D space, houssen, 11/12/2015
- Re: [cgal-discuss] Intersect lines with lines, and, polygons with polygons in 3D space, zell_winston, 11/13/2015
- Re: [cgal-discuss] Intersect lines with lines, and, polygons with polygons in 3D space, houssen, 11/13/2015
- Re: [cgal-discuss] Intersect lines with lines, and, polygons with polygons in 3D space, Sebastien Loriot (GeometryFactory), 11/13/2015
