cgal-discuss - Re: [cgal-discuss] How to build quadratic lines, triangles or polyhedrons ?
  • To: <>
  • Subject: Re: [cgal-discuss] How to build quadratic lines, triangles or polyhedrons ?
  • Date: Mon, 23 Nov 2015 12:30:10 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:PlNMqxeuGiXnjF53Xqa+hvSYlGMj4u6mDksu8pMizoh2WeGdxc65Zh7h7PlgxGXEQZ/co6odzbGG7ua/ASdav96oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDvvcKLKF8WzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePFsRrNRCHEqMns++dbwnRjFVwqGoHUGBDY4iB1NVgjC8QrhU5G55iv9q/Fm1S+yPNX5VfY6Q2LxvO9QVBb0hXJfZHYC+2bNh5kogQ==
Not even in re-implementing shapes or some relevant classes ?
Franck
Le 2015-11-23 12:03, Sebastien Loriot (GeometryFactory) a écrit :
It is not possible.
Sebastien.
On 11/20/2015 04:33 PM, houssen wrote:
Hello,
I am quite new to CGAL.
I succeeded to make my way across creating and manipulating lines
(Segment_3), triangles (Triangle_3), polyhedrons (Polyhedron_3) made of
straight lines in the 3D space.
I try to understand if it is possible (or not ?) to do the same with
splines (curved lines). That is, is it possible to create:
1. a spline (C1 curve) ?
2. a triangle bordered by splines ?
3. a polyhedron whose facets could be bordered by splines ?
If yes, how ? And can I manipulate them as I do it already ? (are there
some code samples related to this ?)
Franck
