- To: <>
- Subject: Re: [cgal-discuss] How to build quadratic lines, triangles or polyhedrons ?
- Date: Mon, 23 Nov 2015 14:15:41 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:mGY7nhFqJcJQa6qosOmA5Z1GYnF86YWxBRYc798ds5kLTJ75pM6wAkXT6L1XgUPTWs2DsrQf27eQ7PirAjxIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niqbto9aIM01hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvK683RLgdADU9OH0u/+XqswPCRE2B/C1PfH8Rl09IBBXe9xz8FsPxtTbhred78CiCMtWwQ6piCmfq1LtiVBK90HRPDDU+6myC0sE=
It seems indeed a bit too much low level for a (not so experienced) CGAL user !... Is there an example available to start on his topic ?
Franck
Le 2015-11-23 13:55, Sebastien Loriot (GeometryFactory) a écrit :
well you can work on the low level HalfedgeDS to get the
graph structure correct and use a face type corresponding to your
needs but there is nothing that will be working out of the box.
Sebastien.
On 11/23/2015 12:30 PM, houssen wrote:
Not even in re-implementing shapes or some relevant classes ?
Franck
Le 2015-11-23 12:03, Sebastien Loriot (GeometryFactory) a écrit :
It is not possible.
Sebastien.
On 11/20/2015 04:33 PM, houssen wrote:
Hello,
I am quite new to CGAL.
I succeeded to make my way across creating and manipulating lines
(Segment_3), triangles (Triangle_3), polyhedrons (Polyhedron_3) made of
straight lines in the 3D space.
I try to understand if it is possible (or not ?) to do the same with
splines (curved lines). That is, is it possible to create:
1. a spline (C1 curve) ?
2. a triangle bordered by splines ?
3. a polyhedron whose facets could be bordered by splines ?
If yes, how ? And can I manipulate them as I do it already ? (are there
some code samples related to this ?)
Franck
- [cgal-discuss] How to build quadratic lines, triangles or polyhedrons ?, houssen, 11/20/2015
- Re: [cgal-discuss] How to build quadratic lines, triangles or polyhedrons ?, houssen, 11/23/2015
- Re: [cgal-discuss] How to build quadratic lines, triangles or polyhedrons ?, Sebastien Loriot (GeometryFactory), 11/23/2015
