cgal-discuss - Re: [cgal-discuss] How to build quadratic lines, triangles or polyhedrons ?
  • To:
  • Subject: Re: [cgal-discuss] How to build quadratic lines, triangles or polyhedrons ?
  • Date: Mon, 23 Nov 2015 13:55:51 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:4PsRhB+veUiw8/9uRHKM819IXTAuvvDOBiVQ1KB91e4cTK2v8tzYMVDF4r011RmSDdidtKoP0LqempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lR8iN14/sh6ibwN76XUZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwu3cYh/V0/MFJVeD2fr8zUKdDJDUgKWE8osPx5jfZSg7arEARWGwNjhtFBUDh6wv7WYu58gT3se9wxDOLE8T9UbcuSHXop/NwTBjyiSAbcTs92G7Sg810yqlcpUTy9FRE34fIbdTNZ7JFdaTHcIZCSA==
well you can work on the low level HalfedgeDS to get the
graph structure correct and use a face type corresponding to your
needs but there is nothing that will be working out of the box.
Sebastien.
On 11/23/2015 12:30 PM, houssen wrote:
Not even in re-implementing shapes or some relevant classes ?
Franck
Le 2015-11-23 12:03, Sebastien Loriot (GeometryFactory) a écrit :
It is not possible.
Sebastien.
On 11/20/2015 04:33 PM, houssen wrote:
Hello,
I am quite new to CGAL.
I succeeded to make my way across creating and manipulating lines
(Segment_3), triangles (Triangle_3), polyhedrons (Polyhedron_3) made of
straight lines in the 3D space.
I try to understand if it is possible (or not ?) to do the same with
splines (curved lines). That is, is it possible to create:
1. a spline (C1 curve) ?
2. a triangle bordered by splines ?
3. a polyhedron whose facets could be bordered by splines ?
If yes, how ? And can I manipulate them as I do it already ? (are there
some code samples related to this ?)
Franck
