cgal-discuss - Re: [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found'
  • To:
  • Subject: Re: [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found'
  • Date: Fri, 15 Jan 2016 09:46:51 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:Oe1kRB3nCJevqHX4smDT+DRfVm0co7zxezQtwd8ZsegQLPad9pjvdHbS+e9qxAeQG96LtbQV06GP6f2ocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0YLmj6vrocCbSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBK71dqB9Qb1DByk9KEg04tfqvF/NV1ih/HwZBy8tnxBBGBTE4ReyepDrsyzm/qpS1S6fMNHsXJ49Uiil9bYqAle8kyMALT8+7CfSjuR/iatapFSqoBkpkN2cW52cKPcrJvCVRtgdX2cUBss=
On 12/02/2015 08:08 AM, yongsheng94 wrote:
I able to compile and run Polyhedron. What i done was copy
libQGLViewer.framework and paste in /Library/Frameworks.
An alternative is to add the path containing libQGLViewer.framework in the environment variable DYLD_FRAMEWORK_PATH.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Fail-to-run-Polyhedron-demo-with-reason-Image-not-found-tp4661416p4661427.html
  • Re: [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found', Sebastien Loriot (GeometryFactory), 01/15/2016
