- To:
- Subject: Re: [cgal-discuss] Create (almost) regural grid from random points
- Date: Fri, 15 Jan 2016 08:56:33 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:DJz6PxWNFvR5iC5pA4CMpX7cqs3V8LGtZVwlr6E/grcLSJyIuqrYZhGPt8tkgFKBZ4jH8fUM07OQ6PC+Hz1Yqs/Y7jgrS99laVwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oM2NJVQQz2PkP/tbF1afk0b4joEum4xsK6I8mFPig0BjXKBo/15uPk+ZhB3m5829r9ZJ+iVUvO89pYYbCf2pN/dwcbsNBzsvNyU55dbgqALYZQqJ/HoVFGsMwTRSBA2Q1xD/WZG5nSrgv/dx3zXSadb3SLcyHzuj9a52RBj0oCgKMDs07HvGhMV7kKVBsVSqoBkpkN2cW52cKPcrJvCVRtgdX2cUBss=
Le 14/01/2016 20:14, Tomil a écrit :
I have a set of random points in 2D.. These points form a DelaunayI'm not sure this is possible with your input (I assume it is much denser than the regular grid you want to get), but why not simply:
Triangulation...(which consists of random triangles)
I want to simplify the original mesh, discarding some of the original points
and create a new triangulation.. So that the new triangles that will emerge,
will be close to equilateral, forming an almost hexagonal grid..
At a first glance, I thought the solution had to do with centroidal voronoi
tessellation (CVT), but in this case the generator points are not part of
the original set...
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Create-almost-regural-grid-from-random-points-tp4661480p4661494.html
* Create a regular grid from scratch (perfectly regular I mean)
* Replace every point of this grid by the closest input point (if an input point is close enough)
Simon Giraudot, PhD
R&D Engineer
GeometryFactory - http://geometryfactory.com/
- [cgal-discuss] Create (almost) regural grid from random points, Tomil, 01/12/2016
- Re: [cgal-discuss] Create (almost) regural grid from random points, Sebastien Loriot (GeometryFactory), 01/14/2016
- Re: [cgal-discuss] Create (almost) regural grid from random points, Tomil, 01/14/2016
- Re: [cgal-discuss] Create (almost) regural grid from random points, Sebastien Loriot (GeometryFactory), 01/15/2016
- Re: [cgal-discuss] Create (almost) regural grid from random points, Simon Giraudot, 01/15/2016
