- To:
- Subject: [cgal-discuss] travessing order vertices arrangement
- Date: Fri, 29 Jan 2016 18:28:32 -0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:PtOLkBAxw1p0390U4ukRUyQJP3N1i/DPJgcQr6AfoPdwSP7/oMbcNUDSrc9gkEXOFd2CrakU1KyO7eu5AzNIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niKbqpdaKOVoArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZn9Kq83RLgdADU9OH0u/+XqswPCRE2B/CgySGITxz9BHwXY91nQU5P1tS79/r540TWXINb8QLQwXjGlx6huQR7sziwAMmhqoynslsVsgfcD81qarBtlztuMbQ==
Hi,
I would like to know if there is a specific order when traversing vertices (and also faces) from Arrangement_2 using the .vertices_begin() iterator (and .faces_begin() iterator). I searched this info in the manual but I did not find it.- [cgal-discuss] travessing order vertices arrangement, Mateus Bellomo, 01/29/2016
- Re: [cgal-discuss] travessing order vertices arrangement, Efi Fogel, 01/30/2016
- Re: [cgal-discuss] travessing order vertices arrangement, Mateus Bellomo, 01/30/2016
