- To:
- Subject: Re: [cgal-discuss] travessing order vertices arrangement
- Date: Sat, 30 Jan 2016 09:59:04 -0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:sAN+uhEyww+mfNjBfHGZSp1GYnF86YWxBRYc798ds5kLTJ75o8mwAkXT6L1XgUPTWs2DsrQf27WQ6/CrAzxIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niKbqq9aJM01hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKsxSflUDS8tLnsuzMztrxjKCwWVtVUGVWBDtxNUDhXepDv3WpP2tyyy4u90xCSHJsf7SbQzXDOK4KJiSRuugyACYW1quFrLg9B92foI6CmqoAZyltbZ
I thought about creating order...
2016-01-30 6:53 GMT-02:00 Efi Fogel <>:
There is none.
What specific order could there be?____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/On Fri, Jan 29, 2016 at 10:28 PM, Mateus Bellomo <> wrote:MateusThanksHi,I would like to know if there is a specific order when traversing vertices (and also faces) from Arrangement_2 using the .vertices_begin() iterator (and .faces_begin() iterator). I searched this info in the manual but I did not find it.
- [cgal-discuss] travessing order vertices arrangement, Mateus Bellomo, 01/29/2016
- Re: [cgal-discuss] travessing order vertices arrangement, Efi Fogel, 01/30/2016
- Re: [cgal-discuss] travessing order vertices arrangement, Mateus Bellomo, 01/30/2016
