- To:
- Subject: [cgal-discuss] Visualization of results of Ridges_3 example.
- Date: Thu, 11 Feb 2016 14:28:50 +0530
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:6+711hJQV6LZjIKL3tmcpTZWNBhigK39O0sv0rFitYgULvrxwZ3uMQTl6Ol3ixeRBMOAu60C0LGd6vq9EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35vxjLv5oseOKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxcK08CLBZFz87KHsd5cvxtBCFQxHcyGEbVzAtjxlIGQHHpCr7WJjx+n/ht+xy2G+BIM72V7k2cTun5qZvDhTvjXFUZHYC7GjLh5ko3+pgqxW7qkknzg==
Hello all,
I would like to see the results of Ridges_3 example.
Referring the Readme text file of the same, I used following option to run the program.
./Compute_Ridges_Umbilics -f data/poly2x^2+y^2-0.062500.off -d4 -m4 -a4 -t3 -v0
I get two output .txt file.
I tried opening one of those which contains the information in raw format, using Polyhedron demo program.
Polyhedron demo asks to choose the plugin to be used to display, I chose <something>.xyz plugin.
It rendered something vague.
Can somebody tell me how can I visualize the results of Ridges_3 ?
Thanks
Sukh
P.S. I am a newbie and this is my first message in this mailing list :) .
- [cgal-discuss] Visualization of results of Ridges_3 example., Sukhraj Singh, 02/11/2016
