- To:
- Subject: Re: [cgal-discuss] Persistent cell identifiers in Triangulation_3
- Date: Thu, 11 Feb 2016 11:18:08 -0400
After some experimentation it seems (assuming the cell has not been removed by a point insertion or vertex deletion) that I can still correctly reference a cell through its Cell_handle after a change to the triangulation.
Yes it is safe to reference a cell b its cell_handle if the cell has not be modified by the modifications done in the triangulation.
But if you have a cell_iterator, it is safe for to access the cell behind the iterator, but if the triangulation has been modified
(even without modifying the current cell) the ++ is no longer safe.
- [cgal-discuss] Persistent cell identifiers in Triangulation_3, Brown, James 2, 02/10/2016
- Re: [cgal-discuss] Persistent cell identifiers in Triangulation_3, Olivier Devillers, 02/11/2016
- Re: [cgal-discuss] Persistent cell identifiers in Triangulation_3, Andreas Fabri, 02/15/2016
