Re: [cgal-discuss] Why is my OFF file producing segmentation fault for polyhedron generation ?
- To:
- Subject: Re: [cgal-discuss] Why is my OFF file producing segmentation fault for polyhedron generation ?
- Date: Thu, 14 Apr 2016 14:05:40 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Can you please send us your command line, and the complete log,
until "Segmentation fault" happens? Are you using the Polyhedral_mesh_domain constructor that takes a filename as parameter? Le 14/04/2016 13:52, Timothée Nicolas a
écrit :
Good question.
I am using CGAL-4.7 2016-04-14 20:49 GMT+09:00 Andreas
Fabri <>:
Are you both sure to use the same releases of CGAL? andreas On 14/04/2016 13:48, Timothée Nicolas wrote: Thank you for your answer. So you say you were able to produce a valid out.mesh file with the .off file I suggested ? I just checked on my Ubuntu computer, and it does the same as this afternoon at work on a Mac OS X. The error message here is Erreur de segmentation (core dumped) If I remember correctly, on the mac, it was something like Segmentation fault:11 I have added the verbose line you sent me, and it does not tell me anything else... Timothée 2016-04-14 19:45 GMT+09:00 Jane Tournois < <mailto:>>: Hi Timothee, I could not reproduce your seg fault. You can try to add the following macro definition on the very first line of your cpp file : #define CGAL_MESH_3_VERBOSE and then post the execution log? This could help you or us find the error. Also, you mention an "error message". What does it say ? Best, Jane. -- Jane Tournois, PhD R&D Engineer at GeometryFactory http://www.geometryfactory.com/ Le 14/04/2016 10:18, Timothée Nicolas a écrit : Dear all, I am trying to produce a 3D tetrahedral mesh from a boundary surface mesh. I figured that the easiest way to do this was to use a .OFF file of my boundary, which does not seem too difficult to produce, and feed it directly to this example program http://doc.cgal.org/latest/Mesh_3/Mesh_3_2mesh_polyhedral_domain_8cpp-example.html Before taking on my actual boundary surface mesh, I need to understand exactly what I am doing, so I tried replacing the file elephant.off with the following simple .off file representing a pyramid OFF 5 6 0 0.0 0.0 0.0 1.0 0.0 0.0 1.0 1.0 0.0 0.0 1.0 0.0 0.5 0.5 1.0 3 2 1 0 3 3 2 0 3 0 1 4 3 1 2 4 3 2 3 4 3 3 0 4 Unfortunately this produces a segmentation fault when making the mesh. I have no idea what causes it to malfunction. Anyone has a clue ? I have also tried with a simple tetrahedron or a cube with each face cut into two triangles, same error message. Best Timothee -- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://sympa.inria.fr/sympa/info/cgal-discuss -- Andreas Fabri, PhD Chief Officer, GeometryFactory Editor, The CGAL Project phone: +33.492.954.912 skype: andreas.fabri -- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://sympa.inria.fr/sympa/info/cgal-discuss -- Jane Tournois, PhD R&D Engineer at GeometryFactory http://www.geometryfactory.com/ |
- [cgal-discuss] Why is my OFF file producing segmentation fault for polyhedron generation ?, Timothée Nicolas, 04/14/2016
- Re: [cgal-discuss] Why is my OFF file producing segmentation fault for polyhedron generation ?, Jane Tournois, 04/14/2016
- Re: [cgal-discuss] Why is my OFF file producing segmentation fault for polyhedron generation ?, Timothée Nicolas, 04/14/2016
- Re: [cgal-discuss] Why is my OFF file producing segmentation fault for polyhedron generation ?, Andreas Fabri, 04/14/2016
