- To:
- Subject: [cgal-discuss] Extracting the segments from a Surface Mesh
- Date: Thu, 12 May 2016 17:46:46 +0530
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:1KTI2RClm6ZLqwZHU3Q1UyQJP3N1i/DPJgcQr6AfoPdwSP7/o8bcNUDSrc9gkEXOFd2CrakU2qyP4uu8ACQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTmkbnjsMGKKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxcK08CLBZFz87KHsd5cvxtBCFQxHcyGEbVzAtjxlIGQHHpCr7WJjx+n/ht+xy2G+BIM72V7k2cTun5qZvDhTvjXFUZHYC7GjLh5ko3+pgqxW7qkknzg==
Salut,
The "Triangulated Surface Mesh Segmentation" module allows one to segment a surface mesh using the SDF values.
It creates a Property Map which is colorized according to the indices, resulting into segments. Two spatially apart areas( i.e. not having common edges) of a Mesh may fall into same segment, since they had comparable SDF values.
My question is, how can one extract these segments. Since I want to do further processing on a segment separately. Also I would like further divide a segment, into say sub-segments , where a sub-segment will have faces which are not spatially apart, i.e. a subset which is having common edges only.
Thanks to inform.
P.S. I am a newbie.
-- Sukhraj Singh
- [cgal-discuss] Extracting the segments from a Surface Mesh, Sukhraj Singh, 05/12/2016
- Re: [cgal-discuss] Extracting the segments from a Surface Mesh, Sebastien Loriot (GeometryFactory), 05/12/2016
- Re: [cgal-discuss] Extracting the segments from a Surface Mesh, Sukhraj Singh, 05/22/2016
- Re: [cgal-discuss] Extracting the segments from a Surface Mesh, Sebastien Loriot (GeometryFactory), 05/23/2016
- Re: [cgal-discuss] Extracting the segments from a Surface Mesh, Sukhraj Singh, 05/23/2016
