cgal-discuss - Re: [cgal-discuss] Extracting the segments from a Surface Mesh
  • To:
  • Subject: Re: [cgal-discuss] Extracting the segments from a Surface Mesh
  • Date: Mon, 23 May 2016 17:08:09 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
If it does what you want, then yes.
Sebastien.
On 05/23/2016 04:57 PM, Sukhraj Singh wrote:
Okay,
Assuming I don't use connected_components().
And I directly create Polyhedrons from the segments, i.e.
- Iterate through polyhedron.
- Create polyhedron of a segment using Polyhedron_incremental_builder_3.
Is this correct way to do ? Or there is some better approach in CGAL.
On Mon, May 23, 2016 at 1:18 PM, Sebastien Loriot (GeometryFactory)
<mailto:>>
wrote:
What I mean is if you need both clusters and segments but want to
save on computation time, you can run the segmentation algorithm to
extract
segments and then clusters using `connected_components()` (instead of
another run of segmentation).
Sebastien.
On 05/22/2016 02:32 PM, Sukhraj Singh wrote:
Thanks for your answer, Sebastien
Do I really need to use connected_components()
I already have the "segment_pmap", where the value is the
segment id to
which that particular face belongs.
And one could parse the Polyhedron and collect all the faces having
particular segment ID.(Of-course I need to check, how to
implement the same)
Is my understanding correct ?
Further, quoting from my previous email:
Two spatially apart areas( i.e. not having
common edges) of a Mesh may fall into same segment, since
they had
comparable SDF values.
I am not sure about it, they of-course may fall into same
cluster, but
may not be to the same segment. In such a case if, faces that don't
share edge, will fall into different segment always, even though
they
were in same cluster, using connected_components() may not be
required ?
On Thu, May 12, 2016 at 6:00 PM, Sebastien Loriot (GeometryFactory)
<mailto:>
<mailto:
<mailto:>>>
wrote:
On 05/12/2016 02:16 PM, Sukhraj Singh wrote:
Salut,
The "Triangulated Surface Mesh Segmentation" module
allows one to
segment a surface mesh using the SDF values.
It creates a Property Map which is colorized according
to the
indices,
resulting into segments. Two spatially apart areas(
i.e. not having
since they had
My question is, how can one extract these segments.
Since I want
to do
further processing on a segment separately. Also I
would like
further
divide a segment, into say sub-segments , where a
sub-segment
will have
faces which are not spatially apart, i.e. a subset
which is having
common edges only.
Set the parameter output_cluster_ids to true when calling the
segmentation function
http://doc.cgal.org/latest/Surface_mesh_segmentation/group__PkgSurfaceSegmentation.html#ga8533ea7b1062ebbabe3bf23fed303f24
If you need also the segments, then set the option to false and
use the function connected_components() considering as
constrained
edges the edges between two faces belonging to different
segments.
http://doc.cgal.org/latest/Polygon_mesh_processing/group__keep__connected__components__grp.html#gabe2052b2281e1e628e68d8fea94be2d9
Sebastien.
Thanks to inform.
P.S. I am a newbie.
Sukhraj Singh
Sukhraj Singh
Sukhraj Singh
