cgal-discuss - Re: [cgal-discuss] Extracting the segments from a Surface Mesh
  • To:
  • Subject: Re: [cgal-discuss] Extracting the segments from a Surface Mesh
  • Date: Sun, 22 May 2016 18:02:21 +0530
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:moNbxBYQxsa2LqJz52rRO8b/LSx+4OfEezUN459isYplN5qZpcW9bnLW6fgltlLVR4KTs6sC0LqH9fuwEjFYqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7H0oM2YPl0ArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZj8ZLkyGLxEECw9YSdy/9zurRCFTA2V53JaXH9RiQtNGwGC7Rf0WdD6vSL+8+Z8wyKHJtalcbdhUjur6+JnSQTjlTwcHz8/6mDezMJq34xBpxf0nAF8w5TdYsmuNfxxfuuJZtIcSmoHRdtSVzZIAKuzaoIOC6wKOuMO/Nq1nEcHsRbrXVrkP+jo0DId3nI=
Thanks for your answer, Sebastien
Do I really need to use connected_components()
I already have the "segment_pmap", where the value is the segment id to which that particular face belongs.
And one could parse the Polyhedron and collect all the faces having particular segment ID.(Of-course I need to check, how to implement the same)
Is my understanding correct ?
Further, quoting from my previous email:
Two spatially apart areas( i.e. not having
common edges) of a Mesh may fall into same segment, since they had
comparable SDF values.
I am not sure about it, they of-course may fall into same cluster, but may not be to the same segment.  In such a case if, faces that don't share edge, will fall into different segment always, even though they were in same cluster, using connected_components() may not be required ?
On Thu, May 12, 2016 at 6:00 PM, Sebastien Loriot (GeometryFactory) <> wrote:
On 05/12/2016 02:16 PM, Sukhraj Singh wrote:
Salut,
The "Triangulated Surface Mesh Segmentation" module allows one to
segment a surface mesh using the SDF values.
It creates a Property Map which is colorized according to the indices,
resulting into segments. Two spatially apart areas( i.e. not having
My question is, how can one extract these segments. Since I want to do
further processing on a segment separately. Also I would like further
divide a segment, into say sub-segments , where a sub-segment will have
faces which are not spatially apart, i.e.  a subset which is having
common edges only.
Set the parameter output_cluster_ids to true when calling the
segmentation function
http://doc.cgal.org/latest/Surface_mesh_segmentation/group__PkgSurfaceSegmentation.html#ga8533ea7b1062ebbabe3bf23fed303f24
If you need also the segments, then set the option to false and
use the function connected_components() considering as constrained
edges the edges between two faces belonging to different
segments.
http://doc.cgal.org/latest/Polygon_mesh_processing/group__keep__connected__components__grp.html#gabe2052b2281e1e628e68d8fea94be2d9
Sebastien.
Thanks to inform.
P.S. I am a newbie.
Sukhraj Singh
Sukhraj Singh
