- To:
- Subject: [cgal-discuss] Something else than Iso_cuboid_3 ?
- Date: Wed, 8 Jun 2016 10:19:24 +0200 (CEST)
Hello,
we are using successfully Alpha_shape_3 with a
Periodic_3_Delaunay_triangulation_traits_3 and a Iso_cuboid_3
(code example is available here :
http://gudhi.gforge.inria.fr/doc/latest/_persistent_cohomology_2periodic_alpha_complex_3d_persistence_8cpp-example.html
And we were wandering to know if it was possible to use something else than
Iso_cuboid_3 ?
We are interested in triclinic systems (
https://en.wikipedia.org/wiki/Triclinic_crystal_system ), where a triclinic
in the Euclidean space E3 with edges not parallel to the x, y and z axis of
the coordinate system.
Thanks in adavance for your answer,
Vincent Rouvreau - http://gudhi.gforge.inria.fr/
INRIA Saclay
Tel: (+33).1.74.85.42.32
- [cgal-discuss] Meshing isosurfaces defined as gray levels in 3D images not possible for large images?, Joan Hensen, 06/06/2016
- [cgal-discuss] Something else than Iso_cuboid_3 ?, Vincent Rouvreau, 06/08/2016
- Re: [cgal-discuss] Something else than Iso_cuboid_3 ?, Monique Teillaud, 06/08/2016
- Re: [cgal-discuss] Meshing isosurfaces defined as gray levels in 3D images not possible for large images?, Laurent Rineau (CGAL/GeometryFactory), 06/10/2016
