- To:
- Subject: Re: [cgal-discuss] Something else than Iso_cuboid_3 ?
- Date: Wed, 8 Jun 2016 17:29:41 +0200
Hi,
CGAL 3D Periodic triangulations are currently only working with an Iso_cuboid_3.
Other shapes would indeed have applications, but unfortunately, due to lack of manpower (/money), there is no work in progress on that for the moment…
Best regards,
Monique Teillaud
http://www.loria.fr/~teillaud/
INRIA Nancy - Grand Est, LORIA
Institut National de Recherche en Informatique et Automatique
Hello,
we are using successfully Alpha_shape_3 with a Periodic_3_Delaunay_triangulation_traits_3 and a Iso_cuboid_3
(code example is available here : http://gudhi.gforge.inria.fr/doc/latest/_persistent_cohomology_2periodic_alpha_complex_3d_persistence_8cpp-example.html )
And we were wandering to know if it was possible to use something else than Iso_cuboid_3 ?
We are interested in triclinic systems ( https://en.wikipedia.org/wiki/Triclinic_crystal_system ), where a triclinic in the Euclidean space E3 with edges not parallel to the x, y and z axis of the coordinate system.
Thanks in adavance for your answer,
Vincent Rouvreau - http://gudhi.gforge.inria.fr/
INRIA Saclay
Tel: (+33).1.74.85.42.32
- [cgal-discuss] Meshing isosurfaces defined as gray levels in 3D images not possible for large images?, Joan Hensen, 06/06/2016
- [cgal-discuss] Something else than Iso_cuboid_3 ?, Vincent Rouvreau, 06/08/2016
- Re: [cgal-discuss] Something else than Iso_cuboid_3 ?, Monique Teillaud, 06/08/2016
- Re: [cgal-discuss] Meshing isosurfaces defined as gray levels in 3D images not possible for large images?, Laurent Rineau (CGAL/GeometryFactory), 06/10/2016
