Re: [cgal-discuss] Meshing isosurfaces defined as gray levels in 3D images not possible for large images?
- To:
- Subject: Re: [cgal-discuss] Meshing isosurfaces defined as gray levels in 3D images not possible for large images?
- Date: Fri, 10 Jun 2016 14:14:42 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:g5Gl4REUluTD+la1Wuthd51GYnF86YWxBRYc798ds5kLTJ75rsywAkXT6L1XgUPTWs2DsrQf27uQ7P+rBTZIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/nhqbtpNaPOU1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv/h7TL7icq8kYbtdBTUgeyBptYy4/SXEGACA739ZXmQNmQdTGCDE6gv7V9H/qHjUrO14jWO+NNDsQLYoEQ6j6apiVVeoowguE3kW/WbSh9BqnYxSqw6mvQ0+icaAZIiILvd4YuXHfNUXTHdpVclYU2pGGIzqPNhHNPYIIesN99q1nFAJtxbrWVih
Le Monday 06 June 2016 20:49:17 Joan Hensen a écrit :
> Hey guys,
> I'm using the example Surface_mesher/mesh_a_3d_gray_image.cpp in order to
> triangulate some 3D images.
> Apparently, there are problems when the images get to large. I have
> generated a test image and tried to apply 'mesh_a_3d_gray_image' on it:
> ./mesh_a_3d_gray_image
> zlib error: data/test.inr: requested length does not fit in int
> _readImage: error: invalid data encountered in 'data/test.inr'
> The image has a size of 2009 x 2009 x 400 voxel.
> I have uploaded all data that you need to reproduce the error:
> https://www.dropbox.com/s/ki5vfqivj1qnsxs/data.zip?dl=0
> Can you help me? I assume that more people would like to triangulate large
> images :-).
Hi,
This bug is know and already fixed in the Git branch will be used to
published
the upcoming bug-fix version CGAL-4.8.1.
The pull-request was:
https://github.com/CGAL/cgal/pull/997
and the patch is limited to only one file:
https://github.com/CGAL/cgal/pull/997/files
You can download the new version of the file here:
https://raw.githubusercontent.com/lrineau/cgal/7bea6910ab6b5ecc1cf27226655c5aa1d3e7a658/CGAL_ImageIO/include/CGAL/ImageIO_impl.h
You will have to recompile the CGAL_ImageIO library once you have patched the
file.
Laurent Rineau, PhD
- [cgal-discuss] Meshing isosurfaces defined as gray levels in 3D images not possible for large images?, Joan Hensen, 06/06/2016
- [cgal-discuss] Something else than Iso_cuboid_3 ?, Vincent Rouvreau, 06/08/2016
- Re: [cgal-discuss] Something else than Iso_cuboid_3 ?, Monique Teillaud, 06/08/2016
- Re: [cgal-discuss] Meshing isosurfaces defined as gray levels in 3D images not possible for large images?, Laurent Rineau (CGAL/GeometryFactory), 06/10/2016
