cgal-discuss - [cgal-discuss] The problem of surface distance computation
  • To:
  • Subject: [cgal-discuss] The problem of surface distance computation
  • Date: Thu, 7 Jul 2016 20:43:00 -0700 (PDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
  • Ironport-phdr: 9a23:WSjgSxZHdAJESFfeCrYHZPH/LSx+4OfEezUN459isYplN5qZpci/bnLW6fgltlLVR4KTs6sC0LuO9fqxEjxYqb+681k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ3pzxjbH5q8WbSj4LrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGxmkql/posZCe26JPxgDO8QMDNzOG884IjntALIUBCUznoaSGQf1BRSUCbf6xSvcZ7rowTn/r5y0TOLY5GuF+htUByt6q5qTFnjjyJRZG1xy33elsEl1fETmxmmvREqmNaMbQ==
Hi,
I have the a problem of computing surface distance about that the processing
time is too long.
The input data I used is big. The surface face is about 3427880 and the
vertices size is 1714008.
Here is what I did.
I used the library of CGAL 4.8.1 - Triangulated Surface Mesh Shortest Paths.
First, I load the input data into the structure of polyhedron.
Then I use following codes to set up the start point and the target point
Surface_mesh_shortest_path shortest_paths(polyhedron);
vertex_descriptor startVertex = vertices[source];
vertex_descriptor endVertex = vertices[target];
// add the first vertex as source
shortest_paths.add_source_point(startVertex);
// compute the surface distance
FT startToEnd =
shortest_paths.shortest_distance_to_source_points(endVertex).first;
However it took too long to process the computation about more than 10
minutes.
In addition, my program could work efficient when data size is 50000 points
about 2~3 seconds processing time.
I saw the benchmark. The biggest dataset used is 17495 points, and it is
efficient.
It can process the 187519 queries per second.
So I want to ask that is it normal that processing such big dataset have to
take more than 10 minutes or even longer ?
Or is it any solution can speed up the computation ?
Thanks,
Gary
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/The-problem-of-surface-distance-computation-tp4662048.html
