cgal-discuss - Re: [cgal-discuss] The problem of surface distance computation
  • To:
  • Subject: Re: [cgal-discuss] The problem of surface distance computation
  • Date: Fri, 08 Jul 2016 09:37:16 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:51fQqhxR2MopQb7XCy+O+j09IxM/srCxBDY+r6Qd0ewWIJqq85mqBkHD//Il1AaPBtSDragVwLOP7OjJYi8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL2PbrnD61zMOABK3bVMzfbWtXNSDxJ3uiKibwN76W01wnj2zYLd/fl2djD76kY0ou7ZkMbs70RDTo3FFKKx8zGJsIk+PzV6nvp/jtM0rzyMFsP0o84tMUL7xYr8jZb1eFjUvdW4vt+PxshyWBzCC7HIHTmQblFJsBBLE6w2yHrj8tS73qvBs9iCRIcrsXPF+EWC566BxSRj0ziIDHzE8+WDTzMd3ifQI81qauxVjztuMM8muP/1kc/aFcA==
Did you try your program with a model with a size similar to the benchmark? If yes, did you observe similar timing?
The mesh you're using is pretty huge. I tried on a 703512 faces mesh and it took me 75s of pre-processing for 10 points on my laptop (10m
might not be surprising then depending on your computer).
Also, you might be getting a memory issue (swapping). Did you check that?
Sebastien.
On 07/08/2016 05:43 AM, GaryGu wrote:
Hi,
I have the a problem of computing surface distance about that the processing
time is too long.
The input data I used is big. The surface face is about 3427880 and the
vertices size is 1714008.
Here is what I did.
I used the library of CGAL 4.8.1 - Triangulated Surface Mesh Shortest Paths.
First, I load the input data into the structure of polyhedron.
Then I use following codes to set up the start point and the target point
Surface_mesh_shortest_path shortest_paths(polyhedron);
vertex_descriptor startVertex = vertices[source];
vertex_descriptor endVertex = vertices[target];
// add the first vertex as source
shortest_paths.add_source_point(startVertex);
// compute the surface distance
FT startToEnd =
shortest_paths.shortest_distance_to_source_points(endVertex).first;
However it took too long to process the computation about more than 10
minutes.
In addition, my program could work efficient when data size is 50000 points
about 2~3 seconds processing time.
I saw the benchmark. The biggest dataset used is 17495 points, and it is
efficient.
It can process the 187519 queries per second.
So I want to ask that is it normal that processing such big dataset have to
take more than 10 minutes or even longer ?
Or is it any solution can speed up the computation ?
Thanks,
Gary
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/The-problem-of-surface-distance-computation-tp4662048.html
