cgal-discuss - Re: [cgal-discuss] Mesh Segmentation Trouble
  • To:
  • Subject: Re: [cgal-discuss] Mesh Segmentation Trouble
  • Date: Fri, 26 Aug 2016 13:07:07 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:H5fAwhDtg1BOWRY3TcBOUyQJP3N1i/DPJgcQr6AfoPdwSPj/psbcNUDSrc9gkEXOFd2CrakV0qyK6+u7ASRAuc/H6yFaNsQUFlcssoY/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbtr8FoOatcmrzef6o8SVOFQRwmblKugqZFXu9EOK55FQ2dMjYo8KiTLx6kNSfOpXwW46bXmypD3bovmKwZh47i5LsOgg/cMTGY/zfqA/UKAKRG9+azN9t4XWswLeR16P+mcESTdR1QFZBhDMqhD8RJb49CXg8fFs3TGTeszwQ7dzUjur6+JnSQTjlTwcZAM/63zd38xskLpA8lXmvA1624eSYYePNfM4cLmaZsIfXWMGX8BfUGtKDYq4KocOFOEcJv0Lko/mulFbrQeiHRL+Q6T02zpQjzn327c72qIvC0bdzQk4FpUPtnrT6976PaNXXeGux7TT1mb/aKZd1j75rYTJaRs8uuqkXLRqcMOXx1N8ORnCiwDakoHvNiiJ1+kL+0yc9etnSarvpGMgrgxtuCmBz8wwjZPYx8hdnkvA8j94x5pzINmQR0tyYNriG5xV4XLJf7BqS98vFjk78B0xzacL7Ma2
The caption says "using 6 clusters".
Sebastien.
On 08/26/2016 12:43 PM, Pablo Sánchez wrote:
I read the note, yes, but I'm kind of confused as to why when I try with
0.26 lambda and 2 clusters I don't get the same result seen in the example.
It looks more like the one with 4 clusters even though I set it to 2.
Pablo Sánchez
2016-08-26 9:42 GMT+02:00 Sebastien Loriot (GeometryFactory)
<mailto:>>:
I got 13 segments.
Did you pay attention to the note here:
http://doc.cgal.org/latest/Surface_mesh_segmentation/index.html#Surface_mesh_segmentationSoftClustering
<http://doc.cgal.org/latest/Surface_mesh_segmentation/index.html#Surface_mesh_segmentationSoftClustering>
Sebastien.
On 08/22/2016 05:27 PM, Pablo Sánchez wrote:
I'll try that value and come back with the results.
Pablo Sánchez
2016-08-22 17:27 GMT+02:00 Sebastien Loriot (GeometryFactory)
<mailto:>
<mailto:
<mailto:>>>:
On 08/22/2016 05:23 PM, Pablo Sánchez wrote:
Hi Sebastien,
I tried using a modified demo in order to get the
segments in
different
meshes. I'm having success in getting the segmented
meshes but
segmentation doesn't seem to change with any of the
parameters.
Could you specify what value of smoothing lambda you used?
The default in the demo: 0.26
Sebastien.
Regards
Pablo Sánchez
2016-08-22 17:20 GMT+02:00 Sebastien Loriot
(GeometryFactory)
<mailto:>
<mailto:
<mailto:>>
<mailto:
<mailto:>
<mailto:
<mailto:>>>>:
I tried using the polyhedron demo on the elephant
model,
selecting 6
clusters and got something that is similar to the
first
image in the
documentation. What did you try?
Sebastien.
On 08/14/2016 03:20 PM, Pablo Sánchez wrote:
Hi,
Lately I've been working with CGAL's mesh
segmentation
functionalities
and I'm having some problems achieving different
segmentations
through
number_of_clusters and smoothing_lambda
parameters.
I'm using your "elephant.off" mesh as an
example, and
as I try
to get
the results you expose in your documentation for
Surface Mesh
Segmentation, I'm not able to get the same kind of
segmentation.
Even though I change the values of the
parameters, I
still get
the same
segmentation in every iteration.
Could I get a hint of what I'm doing wrong?
Regards,
Pablo Sánchez
<https://sympa.inria.fr/sympa/info/cgal-discuss>
<https://sympa.inria.fr/sympa/info/cgal-discuss>>
<https://sympa.inria.fr/sympa/info/cgal-discuss>>>
