cgal-discuss - Re: [cgal-discuss] failed to create straightSkeleton
  • To:
  • Subject: Re: [cgal-discuss] failed to create straightSkeleton
  • Date: Tue, 30 Aug 2016 14:16:40 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:Egm2mR+ATq56Rf9uRHKM819IXTAuvvDOBiVQ1KB92uwcTK2v8tzYMVDF4r011RmSDNydt6wP17ee8/i5HzdRudDZ6DFKWacPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvjotuPPU4U2XL9Oeo0d0Tu612J94E/ushLEu4J0BzHo39FKax95FhDAhatpSv6/dq655V58i5d6LoL/s9EVrjmLexjFeQLRAIPaTFooZW7/VmeFUrcrkcbB24Zmx4NDwne5wzhRb/wtDH7v6xzwnq0J8rzGPoPVD6r9LtqRRmgrCAdNjkluCH4h8t1gb5BsTyorAB42Z+VKsnBL/55ZKLaYZUfQUJOW89QU2pKBYbqPNhHNPYIIesN99q1nFAJtxbrWFGh
Could you provide the input polygon failing as an ascii file?
Thanks,
Sebastien.
On 08/30/2016 10:53 AM, Marcos Dione wrote:
I'm using PostgreSQL 9.5 + PostGIS 2.2.2, the latter in its turn uses
libsfcgal 1.3.0, which in turn uses libcgal 4.8.1 (all this under Debian
Sid). Today, the attached query failed with the following message:
CGAL failed to create straightSkeleton
I managed to work arround the issue by pre simplifying the Polygon.
I'm not sure why the query is failing, and I can't find in CGAL's docs
when or how do they report errors (I guess they just return a null
pointer).
Is this the right place to report this, or should I first try to go
down the stack? As you can see, it's quite deep (I'm even using
python-shapely 1.5.16 on top of all that).
Cheers,
-- Marcos.
