[cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation
- To:
- Subject: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation
- Date: Fri, 2 Sep 2016 22:54:13 +0530
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:1ti2vRbC6o0wR78GFULoVWj/LSx+4OfEezUN459isYplN5qZpcq+bnLW6fgltlLVR4KTs6sC0LuP9f27EjVYsd7B6ClEK80UEUddyI0/pE8JOIa9E0r1LfrnPWQRPf9pcxtbxUy9KlVfA83kZlff8TWY5D8WHQjjZ0IufrymUrDbg8n/7e2u4ZqbO1wO32vkJ+4pZ0zu/U2R7pBQ2to6bP5pi1PgmThhQ6xu32RmJFaezV7Xx/yb29pdyRlWoO8r7MVaUK/3LOwSRL1cCyk6YShuvJW4/UqLcQza7XQVViAakwFDHhPexBD8RJb49CXg5cRn3yzPBtD1Tao9W3yZ7qFkSFe8kyYBOD5/63zUitZ5jopUpRugo1p0xIuCM9LdD+Z3Yq6IJYBSfmFGRMsEDyE=
Hello,
I am trying to create a particular segment (which is the output of surface mesh segmentation) as ROI in Surface Mesh Deformation.
I implemented following code, which is crashing( psb comment below)
void set_all_vertices_as_roi()
vertex_iterator vb, ve;
for(boost::tie(vb, ve) = vertices(*polyhedron()); vb != ve; ++vb)
insert_roi_vertex(*vb);
//Implement it likewise all mesh vertices as roi
void set_segment_vertices_as_roi(Polyhedron mesh)
std::size_t number_of_clusters;
double smoothing_lambda ;
// create a property-map for segment-ids
typedef std::map<Polyhedron::Facet_const_handle, std::size_t> Facet_int_map;
Facet_int_map internal_segment_map;
boost::associative_property_map<Facet_int_map> segment_property_map(internal_segment_map);
//Run the sdf segmentation algo
int nb_segments = SegmentPolyhedron(segment_property_map,number_of_clusters, smoothing_lambda ,mesh);
std::vector <Polyhedron> PolySegments;
PolySegments.resize(nb_segments);
//Get the segement of the mesh
GetSegments(mesh,segment_property_map,nb_segments,PolySegments,0);
//Make zeroth segment as ROI
for(boost::tie(vb, ve) = vertices(PolySegments[0]); vb != ve; ++vb)
//std::cout << __LINE__ << std::endl;
insert_roi_vertex(*vb); // GIVES CRASH
Perhaps it is because of size of deform_mesh, which was equal to complete non-segmented mesh size. ?
There is k-ring selection as well, which is used when picked by mouse.
Can someone suggest me some other way maybe, so that I could make the mesh segment as ROI
Thanks to provide input.
Sukhraj Singh
- [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation, Sukhraj Singh, 09/02/2016
- Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation, Sebastien Loriot (GeometryFactory), 09/05/2016
- Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation, Sukhraj Singh, 09/05/2016
- Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation, Sebastien Loriot (GeometryFactory), 09/06/2016
- Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation, Sukhraj Singh, 09/07/2016
- Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation, Sebastien Loriot (GeometryFactory), 09/07/2016
