- To:
- Subject: Re: [cgal-discuss] triangulation non convex polygon
- Date: Sun, 11 Sep 2016 15:15:24 +0200 (CEST)
On Sun, 11 Sep 2016, Mateus Bellomo wrote:
I would like to know if there is a way of doing a triangulation of a non
convex polygon.
I read about Triangulation_2 [1] but it only refers to convex set of points.
http://doc.cgal.org/latest/Triangulation_2/classCGAL_1_1Constrained__triangulation__2.html or http://doc.cgal.org/latest/Triangulation_2/classCGAL_1_1Constrained__Delaunay__triangulation__2.html should work. If you insert the edges of your polygon as constraints, it will triangulate both the inside and the outside of the polygon.
http://doc.cgal.org/latest/Triangulation_2/index.html#title29 "Example: Triangulating a Polygonal Domain" may help.
Marc Glisse
- [cgal-discuss] triangulation non convex polygon, Mateus Bellomo, 09/11/2016
- Re: [cgal-discuss] triangulation non convex polygon, Narusaki, 09/11/2016
- Re: [cgal-discuss] triangulation non convex polygon, Mateus Bellomo, 09/11/2016
- Re: [cgal-discuss] triangulation non convex polygon, Marc Glisse, 09/11/2016
- Re: [cgal-discuss] triangulation non convex polygon, Narusaki, 09/12/2016
