- To:
- Subject: Re: [cgal-discuss] triangulation non convex polygon
- Date: Sun, 11 Sep 2016 10:54:04 -0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:lkcwExZrAJR7Fb4ZQMxAbfb/LSx+4OfEezUN459isYplN5qZpM28bnLW6fgltlLVR4KTs6sC0LuP9f6/Ej1aqdbZ6TZZIcQKD0dEwewt3CUYSPafDkP6KPO4JwcbJ+9lEGFfwnegLEJOE9z/bVCB6le77DoVBwmtfVEtfre9JIfegoyN2vyo/NWLOkMT1WP7P+w5fU/+7V2I8JJH2c06cud54yCKi0MAQ/5Ry2JsKADbtDfHzeD0wqRe9T9Nsekq7c9KXPayVa05SbtFEGZuaDhtt4W4/STFVhaFs3sATn0NwF0PGBnA9Bi8X5HrsyK8uPA6wzifJcSxTLY6XnOp4K5vDRPpkywaLCVqzGaCgcN5iOdXoQmqugdk64/SeoCccvRkLY3HetZPYGNdU9tKHwZMBoe7aoxHW+8IIetFtIPwo18JqByWCgylBeepwThN0CyllZYm2vgsRFmVlDcrGMgD5SzZ
Thanks Marc.
But what do you mean by "it will triangulate both the inside and the outside of the polygon" ?The problem I'm having is that my polygon is non convex and I need to split the polygon interior into triangles.
2016-09-11 10:15 GMT-03:00 Marc Glisse <>:
On Sun, 11 Sep 2016, Mateus Bellomo wrote:
I would like to know if there is a way of doing a triangulation of a non
convex polygon.
I read about Triangulation_2 [1] but it only refers to convex set of points.
http://doc.cgal.org/latest/Triangulation_2/classCGAL_1_1Constrained__triangulation__2.html or http://doc.cgal.org/latest/Triangulation_2/classCGAL_1_1Constrained__Delaunay__triangulation__2.html should work. If you insert the edges of your polygon as constraints, it will triangulate both the inside and the outside of the polygon.
http://doc.cgal.org/latest/Triangulation_2/index.html#title29 "Example: Triangulating a Polygonal Domain" may help.
Marc Glisse
- [cgal-discuss] triangulation non convex polygon, Mateus Bellomo, 09/11/2016
- Re: [cgal-discuss] triangulation non convex polygon, Narusaki, 09/11/2016
- Re: [cgal-discuss] triangulation non convex polygon, Mateus Bellomo, 09/11/2016
- Re: [cgal-discuss] triangulation non convex polygon, Marc Glisse, 09/11/2016
- Re: [cgal-discuss] triangulation non convex polygon, Narusaki, 09/12/2016
