- To:
- Subject: Re: [cgal-discuss] triangulation non convex polygon
- Date: Sun, 11 Sep 2016 11:56:00 -0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:DYxg6xat8BDEEXMShMTYrvX/LSx+4OfEezUN459isYplN5qZpc++bnLW6fgltlLVR4KTs6sC0LuP9f6/EjVYvN7B6ClEK8McEUddyI0/pE8JPo2sMQXDNvnkbig3ToxpdWRO2DWFC3VTA9v0fFbIo3e/vnY4ExT7MhdpdKyuQtaBx5f/6uap5peGYxlUnCHvJvRpPRCupEPQsNMXiM1sMOEq2x7RqzxJfepRgmhnLFbWkxfn7dqr581f9HFbtPslssJBSq7nZL8QTLpCDT1gPXpmytfssEzmRBeC+2BUeGgSlh1NBECR6RjmU4rquCb+su143wGVOMT3SfY/XjH0vPQjcwPhlCpSb21xy2rQkMEl1K8=
Hmm...my polygons won't have holes. In that case can I assume that the only triangulated area will be the polygon interior?
2016-09-11 11:10 GMT-03:00 Narusaki <>:
By "inside and outside", I guess Marc means that if your polygon is genus-n
where n > 0, all the "holes" will also be triangulated.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/triangulation-non-convex-polygon-tp4662251p4662256.html
- [cgal-discuss] triangulation non convex polygon, Mateus Bellomo, 09/11/2016
- Re: [cgal-discuss] triangulation non convex polygon, Narusaki, 09/11/2016
- Re: [cgal-discuss] triangulation non convex polygon, Mateus Bellomo, 09/11/2016
- Re: [cgal-discuss] triangulation non convex polygon, Marc Glisse, 09/11/2016
- Re: [cgal-discuss] triangulation non convex polygon, Narusaki, 09/12/2016
