- To:
- Subject: Re: [cgal-discuss] 3D Mesh Generation: What happened to medit?
- Date: Wed, 21 Sep 2016 12:23:23 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:kIKz/h+fCorLLP9uRHKM819IXTAuvvDOBiVQ1KB+2+McTK2v8tzYMVDF4r011RmSDN+ds6gP0rue8/i5HzdfsdDZ6DFKWacPfiFGoP1epxYnDs+BBB+zB9/RRAt+Iv5/UkR49WqwK0lfFZW2TVTTpnqv8WxaQU2nZkImbtjyT4XdhsDy2+Gp8IDIeC1JgiC8aPV8NkaYtwLU4+AQjZFvI7155BLDuHoAL+1QyXllLEnVkR/2/MaY85Nk9ilMoeMv/sVcVr/rOa8/SOoLX3wdL2kp6Ziz5lH4RgyV6y5EXw==
Seems to have moved here:
https://www.ljll.math.upmc.fr/frey/software.html
On 21/09/2016 11:47, Michael Bieri wrote:
Hi all,
I'm currently learning how to use the 3D Mesh Generation package of
CGAL. The package outputs to the medit file format, for example in this
example: http://doc.cgal.org/latest/Mesh_3/index.html#title15
I tried to get more information about the format and to get the medit
viewer, but all the links seem to be dead. (For example,
here: https://www.rocq.inria.fr/gamma/gamma/Logiciels/index.en.html)
I'm not sure: Is there still a way to use the medit format, or should I
switch to another format? What's the best practice to output and
visualize meshes from CGAL? It will go into an FEM simulaiton later on,
but it's not yet clear, which one. So I'd just like to have an output
that is as versatile and compatible as possible.
Best regards,
Michael
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] 3D Mesh Generation: What happened to medit?, Michael Bieri, 09/21/2016
- Re: [cgal-discuss] 3D Mesh Generation: What happened to medit?, Andreas Fabri, 09/21/2016
- Re: [cgal-discuss] 3D Mesh Generation: What happened to medit?, Michael Bieri, 09/22/2016
- Re: [cgal-discuss] 3D Mesh Generation: What happened to medit?, Andreas Fabri, 09/22/2016
- Re: [cgal-discuss] 3D Mesh Generation: What happened to medit?, Sebastien Loriot (GeometryFactory), 09/26/2016
