cgal-discuss - Re: [cgal-discuss] 3D Mesh Generation: What happened to medit?
  • To:
  • Subject: Re: [cgal-discuss] 3D Mesh Generation: What happened to medit?
  • Date: Mon, 26 Sep 2016 11:21:50 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:XqhPbBwIv6qr3hzXCy+O+j09IxM/srCxBDY+r6Qd0OsXIJqq85mqBkHD//Il1AaPBtSBrasfwLON+4nbGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2WVTerzWI4CIIHV2nbEwud76zQ9WZ1p///tvx0qWbWx9Piju5bOE6BzSNhiKViPMrh5B/IL060BrDrygAUe1XwWR1OQDbxE6ktY/jtKNl6Dla7vI969ZbA+K9ZLU9VbUeDTI8Mmlz6tesrgjGVQLI530SVSIdnRNMRgTE9xrnRYyijiyvveV03GyWPNb9UKsvcTWk9aZiDhHy2wkdMDtsulragMVrkKNWplqFoAZ+xJKcIK6YM/9zYrnMU9oRWW1bT4cbH3haBoSmbowTSe8FFeldpoj54VAJqE3tVkGXGOrzx2oQ1TfN1qog3rF5HA==
There is a non documented header include/CGAL/IO/Complex_3_in_triangulation_3_to_vtk.h
that will give you an vtkUnstructuredGrid as output.
Sebastien.
On 09/22/2016 11:03 AM, Michael Bieri wrote:
Thanks Andreas for that answer.
In general, is it still recommended to use the MEDIT .mesh format or
does the CGAL community prefer something else? (Though, the 3D Mesh
Generation package seems to know only the MEDIT format...)
Best regards,
Michael
On Wed, Sep 21, 2016 at 12:23 PM, Andreas Fabri
<mailto:>>
wrote:
Seems to have moved here:
https://www.ljll.math.upmc.fr/frey/software.html
<https://www.ljll.math.upmc.fr/frey/software.html>
On 21/09/2016 11:47, Michael Bieri wrote:
Hi all,
I'm currently learning how to use the 3D Mesh Generation package of
CGAL. The package outputs to the medit file format, for example
in this
example: http://doc.cgal.org/latest/Mesh_3/index.html#title15
<http://doc.cgal.org/latest/Mesh_3/index.html#title15>
I tried to get more information about the format and to get the
medit
viewer, but all the links seem to be dead. (For example,
here:
https://www.rocq.inria.fr/gamma/gamma/Logiciels/index.en.html
<https://www.rocq.inria.fr/gamma/gamma/Logiciels/index.en.html>)
I'm not sure: Is there still a way to use the medit format, or
should I
switch to another format? What's the best practice to output and
visualize meshes from CGAL? It will go into an FEM simulaiton
later on,
but it's not yet clear, which one. So I'd just like to have an
output
that is as versatile and compatible as possible.
Best regards,
Michael
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 <tel:%2B33.492.954.912> skype: andreas.fabri
<https://sympa.inria.fr/sympa/info/cgal-discuss>
