- To:
- Subject: Re: [cgal-discuss] How do I construct a WritablePropertyMap?
- Date: Fri, 4 Nov 2016 16:17:12 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:XVtkfBz13sh0KLDXCy+O+j09IxM/srCxBDY+r6Qd0OkVIJqq85mqBkHD//Il1AaPBtSBraIVwLeH++C4ACpbvsbH6ChDOLV3FDY7yuwu1zQ6B8CEDUCpZNXLVAcdWPp4aVl+4nugOlJUEsutL3fbo3m18CJAUk6nbVk9dazIHJXPhZG3y/yq4M+UJB5ZgSK0J7J0NhS/6wvL8dIHhJNrbac3xByOqXRBf6FaxHhjOEmIzCv6/dq6qZ5/7zxL6bVm7N9FSay8fqIiTLUeAi5hKHEw/MSstB/NSkyE6XIYF2kXiRFVGBOW0RfhQ52ksjfmrvEvn26BLMjuRPY1Xy6j5uFlUljzmSIfPnk49m/Qzcd/haYerBO6rAFk2N3oZ9SeO/N6O6/cZtgHXnFpX8BLViUHDJnvQZEICr8gNP1fqcHYrl0JqRKlTV21Hf/ozjJOi1f52KQ716IqFgSQj19oJM4HrHmB9Ia9D6wVS+3glKQ=
CGAL::Polyhedron_3<CGAL::Exact_predicates_inexact_constructions_kernel>
On 4 November 2016 at 16:10, Sebastien Loriot (GeometryFactory) <> wrote:
What is your polyhedron type?
Sebastien.
On 11/04/2016 02:59 PM, Iason Manolas wrote:
My program crashes when I call compute_vertex_normals.
The stack calling the function that crashes is:
4.In *compute_normal.h*at line 183: *(!is_border**(he,pmesh))*
3.In *helpers.h* at line 45: *face(hd,g)*
2.In *graph_traits_Polyhedron_3.h* at line: 420: *h->face();*
1.In H*alfedgeDS_halfedge_base.h* at line 327:*face()*
The error I get in Qt creator is SIGSEGV
<http://stackoverflow.com/questions/2454192/whats-sigsegv-segmentation-fault-in-qt>
which after searching found out that propably means: "Trying to access
pointer with invalid value."
My guess was that I had not correctly initialized the Polyhedron but
everything seems fine..
Any idea why this happens?
Best Regards,
Iason Manolas
On 1 November 2016 at 10:53, Andreas Fabri
<<mailto:>> wrote:
You must
#include <boost/property_map/property_map.hpp>
and write
compute_vertex_normals(P,boost::make_assoc_property_map(normals))
On 01/11/2016 09:45, Iason Manolas wrote:
Thanks for your response Sebastien.
After reading your code I wrote:
using vd=boost::graph_traits<CGALPolyhedron>::vertex_descriptor;
std::map<vd,Kernel::Vector_3>* normals;
CGAL::Polygon_mesh_processing::compute_vertex_normals(P,normals); (since
I want to compute vertex and not face normals)
But I get:
/usr/include/CGAL/Polygon_mesh_processing/compute_normal.h:228:
error:
no matching function for call to
‘put(std::map<CGAL::internal::In_place_list_iterator<CGAL::HalfedgeDS_in_place_list_vertex<CGAL::I_Polyhedron_vertex<CGAL::HalfedgeDS_vertex_base<CGAL::HalfedgeDS_list_types<CGAL::Epick,
CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>,
std::allocator<int> >, CGAL::Boolean_tag<true>,
CGAL::Point_3<CGAL::Epick> > > >,
std::allocator<CGAL::HalfedgeDS_in_place_list_vertex<CGAL::I_Polyhedron_vertex<CGAL::HalfedgeDS_vertex_base<CGAL::HalfedgeDS_list_types<CGAL::Epick,
CGAL::Point_3<CGAL::Epick> > > > > >,
CGAL::Vector_3<CGAL::Epick> >&,
CGAL::HDS_graph_traits<CGAL::Polyhedron_3<CGAL::Epick>
::vertex_descriptor&,
CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double,
CGAL::Epick>, CGAL::Epick>::Vector_3&)’
put(vnm, v, vec);
That propably means that the put fuction cannot recognize vnm ( I
passed) as a valid argument?
On 1 November 2016 at 09:50, Sebastien Loriot (GeometryFactory)
< <mailto:>phone: +33.492.954.912 <tel:%2B33.492.954.912> skype: andreas.fabri<mailto: <mailto:>>> wrote:
A writable property map, as describe in the concept of the
boost web
site is a mecanism that allow to generically associate a
property
(the value type) to a given object (the key).
If you want to associate a normal to a facet of a
Polyhedron, here
is a simple example (not tested):
struct Poly_normal_map{
typedef Polyhedron::Facet_handle key_type;
typedef Kernel::Vector_3 value_type;
typedef boost::writable_property_map_tag category;
std::map<Polyhedron::Facet_handle, Kernel::Vector_3>* normals;
Poly_normal_map() : normals(NULL)
Poly_normal_map(std::map<Polyhedron::Facet_handle,
Kernel::Vector_3>& n)
: normals(*n)
friend void put(Poly_normal_map pnm,
Polyhedron::Facet_handle fh,
const Kernel::Vector_3& n
CGAL_assertion(pnm.normals!=0);
pnm.normals.insert( std::make_pair(fh, n) );
std::map<Polyhedron::Facet_handle, Kernel::Vector_3> normals;
Poly_normal_map vpm(normals); //vpm is you writable property map
If you want to make the property map read-write, you can add
a get function:
friend const value_type& get(Poly_normal_map pnm,
Polyhedron::Facet_handle fh)
return pnm.normals[fh];
and update the category tag.
Note that the code I've written is roughly equivalent to using a
boost::associative_property_map
(http://www.boost.org/doc/libs/1_62_0/libs/property_map/doc/associative_property_map.html
<http://www.boost.org/doc/libs/1_62_0/libs/property_map/doc/associative_property_map.html>
<http://www.boost.org/doc/libs/1_62_0/libs/property_map/doc/associative_property_map.html>>)
boost::associative_property_map<
Kernel::Vector_3> > vpm(normals);
If you're not stuck with Polyhedron_3, you can use class
Surface_mesh that comes with its own property mechanism
as illustrated in this example:
http://doc.cgal.org/latest/Polygon_mesh_processing/Polygon_mesh_processing_2compute_normals_example_8cpp-example.html
<http://doc.cgal.org/latest/Polygon_mesh_processing/Polygon_mesh_processing_2compute_normals_example_8cpp-example.html>
<http://doc.cgal.org/latest/Polygon_mesh_processing/Polygon_mesh_processing_2compute_normals_example_8cpp-example.html>>
Sebastien.
On 10/31/2016 12:46 PM, Iason Manolas wrote:
Hi,
I am new to CGAL. I have constructed a
CGAL::Polyhedron_3 and
now I want
to compute the normal vector for each of its vertices. So I
found the
Polygon Mesh Processing package which happens to have a
function
<http://doc.cgal.org/latest/Polygon_mesh_processing/group__PMP__normal__grp.html#gad46aaf003999b2939f3f9e4f6fa58d0e
<http://doc.cgal.org/latest/Polygon_mesh_processing/group__PMP__normal__grp.html#gad46aaf003999b2939f3f9e4f6fa58d0e>
<http://doc.cgal.org/latest/Polygon_mesh_processing/group__PMP__normal__grp.html#gad46aaf003999b2939f3f9e4f6fa58d0e>>>
doing exactly what I want . In the above link I found
out that the
second argument was of type VertexNormalMap which is a
model of
WritablePropertyMap. There was a link
<http://www.boost.org/doc/libs/1_62_0/libs/property_map/doc/WritablePropertyMap.html
<http://www.boost.org/doc/libs/1_62_0/libs/property_map/doc/WritablePropertyMap.html>
<http://www.boost.org/doc/libs/1_62_0/libs/property_map/doc/WritablePropertyMap.html>>>
to boost libraries explaining(?) what writable property
map is .
Unfortunately this is my first encounter with property
maps and
consequently I am a bit confused..
I also had a look at cgal's explanation of property maps
page
<http://doc.cgal.org/latest/Property_map/index.html
<http://doc.cgal.org/latest/Property_map/index.html>
<http://doc.cgal.org/latest/Property_map/index.html>> >, but I
did not
understand much..
Could anyone suggest a way of creating the property map
I need?
Best Regards,
Iason
<https://sympa.inria.fr/sympa/info/cgal-discuss>
<https://sympa.inria.fr/sympa/info/cgal-discuss>>
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
- Re: [cgal-discuss] How do I construct a WritablePropertyMap?, Sebastien Loriot (GeometryFactory), 11/01/2016
- Re: [cgal-discuss] How do I construct a WritablePropertyMap?, Iason Manolas, 11/01/2016
- Re: [cgal-discuss] How do I construct a WritablePropertyMap?, Andreas Fabri, 11/01/2016
- Re: [cgal-discuss] How do I construct a WritablePropertyMap?, Iason Manolas, 11/04/2016
- Re: [cgal-discuss] How do I construct a WritablePropertyMap?, Sebastien Loriot (GeometryFactory), 11/04/2016
- Re: [cgal-discuss] How do I construct a WritablePropertyMap?, Sebastien Loriot (GeometryFactory), 11/07/2016
- Re: [cgal-discuss] How do I construct a WritablePropertyMap?, Iason Manolas, 11/07/2016
- Re: [cgal-discuss] How do I construct a WritablePropertyMap?, Iason Manolas, 11/10/2016
- <Possible follow-up(s)>
