cgal-discuss - Re: [cgal-discuss] How do I construct a WritablePropertyMap?
  • To:
  • Subject: Re: [cgal-discuss] How do I construct a WritablePropertyMap?
  • Date: Fri, 4 Nov 2016 15:59:57 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
My program crashes when I call compute_vertex_normals.
The stack calling the function that crashes is:
4.In compute_normal.h at line 183: (!is_border(he,pmesh))
3.In helpers.h at line 45: face(hd,g)
2.In graph_traits_Polyhedron_3.h at line: 420: h->face();
1.In HalfedgeDS_halfedge_base.h at line 327: face()
The error I get in Qt creator is SIGSEGV which after searching found out that propably means: "Trying to access pointer with invalid value."
My guess was that I had not correctly initialized the Polyhedron but everything seems fine..
Any idea why this happens?
Best Regards,
Iason Manolas
On 1 November 2016 at 10:53, Andreas Fabri <> wrote:
You must
#include <boost/property_map/property_map.hpp>
and write
compute_vertex_normals(P,boost::make_assoc_property_map(normals))
On 01/11/2016 09:45, Iason Manolas wrote:
Thanks for your response Sebastien.
After reading your code  I wrote:
using vd=boost::graph_traits<CGALPolyhedron>::vertex_descriptor;
std::map<vd,Kernel::Vector_3>* normals;
CGAL::Polygon_mesh_processing::compute_vertex_normals(P,normals); (since
I want to compute vertex and not face normals)
But I get:
/usr/include/CGAL/Polygon_mesh_processing/compute_normal.h:228: error:
no matching function for call to
‘put(std::map<CGAL::internal::In_place_list_iterator<CGAL::HalfedgeDS_in_place_list_vertex<CGAL::I_Polyhedron_vertex<CGAL::HalfedgeDS_vertex_base<CGAL::HalfedgeDS_list_types<CGAL::Epick,
CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>,
std::allocator<int> >, CGAL::Boolean_tag<true>,
CGAL::Point_3<CGAL::Epick> > > >,
std::allocator<CGAL::HalfedgeDS_in_place_list_vertex<CGAL::I_Polyhedron_vertex<CGAL::HalfedgeDS_vertex_base<CGAL::HalfedgeDS_list_types<CGAL::Epick,
CGAL::Point_3<CGAL::Epick> > > > > >, CGAL::Vector_3<CGAL::Epick> >&,
CGAL::HDS_graph_traits<CGAL::Polyhedron_3<CGAL::Epick>
::vertex_descriptor&,
CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double,
CGAL::Epick>, CGAL::Epick>::Vector_3&)’
     put(vnm, v, vec);
That propably means that the put fuction cannot recognize vnm ( I
passed) as a valid argument?
On 1 November 2016 at 09:50, Sebastien Loriot (GeometryFactory)
< <mailto:>> wrote:
    A writable property map, as describe in the concept of the boost web
    site is a mecanism that allow to generically associate a property
    (the value type) to a given object (the key).
    If you want to associate a normal to a facet of a Polyhedron, here
    is a simple example (not tested):
    struct Poly_normal_map{
      typedef Polyhedron::Facet_handle key_type;
      typedef Kernel::Vector_3 value_type;
      typedef boost::writable_property_map_tag category;
      std::map<Polyhedron::Facet_handle, Kernel::Vector_3>* normals;
      Poly_normal_map() : normals(NULL)
      Poly_normal_map(std::map<Polyhedron::Facet_handle,
                               Kernel::Vector_3>& n)
        : normals(*n)
      friend void put(Poly_normal_map pnm,
                      Polyhedron::Facet_handle fh,
                      const Kernel::Vector_3& n
        CGAL_assertion(pnm.normals!=0);
        pnm.normals.insert( std::make_pair(fh, n) );
    std::map<Polyhedron::Facet_handle, Kernel::Vector_3> normals;
    Poly_normal_map vpm(normals); //vpm is you writable property map
    If you want to make the property map read-write, you can add
    a get function:
      friend const value_type& get(Poly_normal_map pnm,
                                   Polyhedron::Facet_handle fh)
        return pnm.normals[fh];
    and update the category tag.
    Note that the code I've written is roughly equivalent to using a
    boost::associative_property_map
    (http://www.boost.org/doc/libs/1_62_0/libs/property_map/doc/associative_property_map.html
    <http://www.boost.org/doc/libs/1_62_0/libs/property_map/doc/associative_property_map.html>)
    boost::associative_property_map<
                      Kernel::Vector_3> > vpm(normals);
    If you're not stuck with Polyhedron_3, you can use class
    Surface_mesh that comes with its own property mechanism
    as illustrated in this example:
    http://doc.cgal.org/latest/Polygon_mesh_processing/Polygon_mesh_processing_2compute_normals_example_8cpp-example.html
    <http://doc.cgal.org/latest/Polygon_mesh_processing/Polygon_mesh_processing_2compute_normals_example_8cpp-example.html>
    Sebastien.
    On 10/31/2016 12:46 PM, Iason Manolas wrote:
        Hi,
        I am new to CGAL. I have constructed a CGAL::Polyhedron_3 and
        now I want
        to compute the normal vector for each of its vertices. So I
        found the
        Polygon Mesh Processing package which happens to have a function
        <http://doc.cgal.org/latest/Polygon_mesh_processing/group__PMP__normal__grp.html#gad46aaf003999b2939f3f9e4f6fa58d0e
        <http://doc.cgal.org/latest/Polygon_mesh_processing/group__PMP__normal__grp.html#gad46aaf003999b2939f3f9e4f6fa58d0e>>
        doing exactly what I want . In the above link I found out that the
        second argument was of type  VertexNormalMap which is a model of
        WritablePropertyMap. There was a link
        <http://www.boost.org/doc/libs/1_62_0/libs/property_map/doc/WritablePropertyMap.html
        <http://www.boost.org/doc/libs/1_62_0/libs/property_map/doc/WritablePropertyMap.html>>
        to boost libraries explaining(?) what writable property map is .
        Unfortunately this is my first encounter with property maps and
        consequently I am a bit confused..
        I also had a look at cgal's explanation of property maps page
        <http://doc.cgal.org/latest/Property_map/index.html
        <http://doc.cgal.org/latest/Property_map/index.html> >, but I
        did not
        understand much..
        Could anyone suggest a way of creating the property map I need?
        Best Regards,
        Iason
    <https://sympa.inria.fr/sympa/info/cgal-discuss>
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912    skype: andreas.fabri
