- To:
- Subject: [cgal-discuss] make_mesh_3 results in non-manifold edges in surface mesh
- Date: Sun, 20 Nov 2016 19:35:56 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:YOVl9xN3TvP6fAWlhO8l6mtUPXoX/o7sNwtQ0KIMzox0K/r8rarrMEGX3/hxlliBBdydsKMfzbCM+Pm5AiRAuc/H6y9SNsQUFlcssoY/oU8JOIa9E0r1LfrnPWQRPf9pcxtbxUy9KlVfA83kZlff8TWY5D8WHQjjZ0IufrymUt2as8Pi3O+7/9jfYh5DmSGmSbJ0NhS/6wvL5ecMho43Eq8t0BrCoTMcY+1KwGpuDV2Wlhf4oMy3+cgwoGxrp/s9+psYAu3BdKMiQOkAAQ==
Hi,
I've been using CGAL to mesh (approximations to) fattened gyroid surfaces, confined to a box from an implicit function. Attached is a simple example code. Unfortunately, this results in a surface mesh containing a non-manifold edge (with 4 faces attached to it). this problem seems to persist in the tet mesh that was generated (I wrote a little program to recalculate its surface mesh). Am I making some silly mistake here? Is there any way to fix it?
Thanks,
Patrick
#include <iostream> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/Mesh_triangulation_3.h> #include <CGAL/Mesh_complex_3_in_triangulation_3.h> #include <CGAL/Mesh_criteria_3.h> #include <CGAL/Implicit_mesh_domain_3.h> #include <CGAL/make_mesh_3.h> //#include "utils.hpp" using std::abs; using std::min; using std::max; using std::string; const double pi = 3.14159265358979323846; template <class type> inline type min( type a, type b, type c ) { const type m = std::min( a, b ); return std::min( m, c ); } template <class type> inline type max( type a, type b, type c ) { const type m = std::max( a, b ); return std::max( m, c ); } template <class type> inline type sqr( type a ) { return a*a; } typedef CGAL::Exact_predicates_inexact_constructions_kernel K; typedef K::FT FT; typedef K::Point_3 Point; typedef FT (Function)(const Point&); typedef CGAL::Implicit_mesh_domain_3<Function,K> Mesh_domain; //#ifdef CGAL_CONCURRENT_MESH_3 typedef CGAL::Parallel_tag Concurrency_tag; //#else //typedef CGAL::Sequential_tag Concurrency_tag; //#endif // Triangulation typedef CGAL::Mesh_triangulation_3<Mesh_domain,CGAL::Default,Concurrency_tag>::type Tr; typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr> C3t3; // Criteria typedef CGAL::Mesh_criteria_3<Tr> Mesh_criteria; // To avoid verbose function and named parameters call using namespace CGAL::parameters; // Function // ---- Start here to define volume ---- const FT box_size_x = 4.0; // box goes from x=0 to x=box_size_x! const FT box_size_y = 4.0; // box goes from y=0 to y=box_size_y! const FT box_size_z = 4.0; // box goes from z=0 to z=box_size_z! const FT factor = 1.0; const FT num_unit_x = 1.0; const FT num_unit_y = 1.0; const FT num_unit_z = 1.0; const FT thickness = 0.8; FT gyroid (const Point &p) { const FT x = p.x(), y = p.y(), z = p.z(); const FT scale_x = num_unit_x*2.0*pi / box_size_x; const FT scale_y = num_unit_y*2.0*pi / box_size_y; const FT scale_z = num_unit_z*2.0*pi / box_size_z; return abs(cos(scale_x*x) * sin(scale_y*y) + cos(scale_y*y)*sin(scale_z*z) + cos(scale_z*z)*sin(scale_x*x)) - thickness; } FT box (const Point &p) { const FT x = p.x(), y = p.y(), z = p.z(); const FT x_center = box_size_x/2.0, y_center = box_size_y/2.0, z_center = box_size_z/2.0; return max(2.0/(factor*box_size_x) * abs(x-x_center), 2.0/(factor*box_size_y) * abs(y-y_center), 2.0/(factor*box_size_z) * abs(z-z_center))-1.0; } FT impl_function (const Point&p) { return max(gyroid(p),box(p)); //return min(box(p), schwp(p)); //return min(box(p), ellipse(p)); } // parameters const FT fa = 30.0; // This parameter controls the shape of surface facets. Actually, // it is a lower bound for the angle (in degree) of // surface facets. When boundary surfaces are smooth, the // termination of the meshing process is guaranteed if the angular bound is at most 30 degrees. const FT fs = 0.1; // This parameter controls the size of surface facets. // Actually, each surface facet has a surface // Delaunay ball which is a ball circumscribing the surface // facet and centered on the surface patch. The parameter facet_size // is either a constant or a spatially variable scalar field, providing an // upper bound for the radii of surface Delaunay balls. const FT fd = 0.025; // This parameter controls the approximation error of boundary and // subdivision surfaces. Actually, it is either a constant or a spatially // variable scalar field. It provides an upper bound for the distance // between the circumcenter of a surface facet and the center of a // surface Delaunay ball of this facet. // facet_topology = 1.0 // This parameters controls the set of topological constraints which have to // be verified by each surface facet. By default, each vertex of a surface facet has // to be located on a surface patch, on a curve segment, or on a corner. It can also // be set to check whether the three vertices of a surface facet belongs to the same // surface patch. This has to be done cautiously, as such a criteria needs that // each surface patches intersection is an input 1-dimensional feature. const FT crer = 1.8; // This parameter controls the shape of mesh cells (but can't filter slivers, as // we discussed earlier). Actually, it is an upper bound for the ratio between the // circumradius of a mesh tetrahedron and its shortest edge. There is a theoretical // bound for this parameter: the Delaunay refinement process is guaranteed to // terminate for values of cell_radius_edge_ratio bigger than 2. const FT cs = 0.1; // This parameter controls the size of mesh tetrahedra. It is either a scalar or a // spatially variable scalar field. It provides an upper bound on the circumradii of // the mesh tetrahedra. int main() { // Domain (Warning: Sphere_3 constructor uses squared radius !) const Point center(box_size_x/2.0, box_size_y/2.0, box_size_z/2.0); const FT radsq = sqr(factor*box_size_x/2.0) + sqr(factor*box_size_y/2.0) + sqr(factor*box_size_z/2.0)+0.1; //std::cerr << impl_function(center); Mesh_domain domain(impl_function, K::Sphere_3(center, radsq)); // Mesh criteria Mesh_criteria criteria(facet_angle=fa, facet_size=fs, facet_distance=fd, cell_radius_edge_ratio=crer, cell_size=cs); // Mesh generation //C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria, odt(), perturb(), exude()); C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria); // Output std::ofstream medit_file("out.mesh"); c3t3.output_to_medit(medit_file); medit_file.close(); std::ofstream off_file("out.off"); c3t3.output_boundary_to_off(off_file); off_file.close(); return 0; }
- [cgal-discuss] make_mesh_3 results in non-manifold edges in surface mesh, Patrick, 11/20/2016
- Re: [cgal-discuss] make_mesh_3 results in non-manifold edges in surface mesh, Laurent Rineau (CGAL/GeometryFactory), 11/21/2016
- Re: [cgal-discuss] make_mesh_3 results in non-manifold edges in surface mesh, Patrick, 11/21/2016
