- To:
- Subject: Re: [cgal-discuss] make_mesh_3 results in non-manifold edges in surface mesh
- Date: Mon, 21 Nov 2016 11:57:54 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:7aWf0BxDAKDhi7jXCy+O+j09IxM/srCxBDY+r6Qd0eoQIJqq85mqBkHD//Il1AaPBtSAragewLCG6OigATVGusnR9ihaMdRlbFwst4Y/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbre9JomHhMu+06W++obYfh5TrDu7e7J7ahus/ivLscxDy69rN7w8zAeBmHpOdu1LjSNDCnu32Dnx4cK94IRy3S1bp/U75o8KGfH+drkiQLpESi4nNW08+eXguhDHCwyV6S1PAS0tjhNUDl2dv1nBVZDrv36iuw==
Le Sunday, November 20, 2016 7:35:56 PM CET Patrick a écrit :
> Hi,
> I've been using CGAL to mesh (approximations to) fattened gyroid surfaces,
> confined to a box from an implicit function. Attached is a simple example
> code. Unfortunately, this results in a surface mesh containing a
> non-manifold edge (with 4 faces attached to it). this problem seems to
> persist in the tet mesh that was generated (I wrote a little program to
> recalculate its surface mesh). Am I making some silly mistake here? Is
> there any way to fix it?
There is an undocumented parameter that you may want to try... Add `facet_topology=CGAL::MANIFOLD,` in the parameters of `Mesh_criteria_3`, to enforce the manifoldness of the output. However, if mesh domain has not a manifold surface, the execution may loop and eventually crash. Use it carefully.
Laurent Rineau, PhD
- [cgal-discuss] make_mesh_3 results in non-manifold edges in surface mesh, Patrick, 11/20/2016
- Re: [cgal-discuss] make_mesh_3 results in non-manifold edges in surface mesh, Laurent Rineau (CGAL/GeometryFactory), 11/21/2016
- Re: [cgal-discuss] make_mesh_3 results in non-manifold edges in surface mesh, Patrick, 11/21/2016
