- To:
- Subject: Re: [cgal-discuss] make_mesh_3 results in non-manifold edges in surface mesh
- Date: Mon, 21 Nov 2016 17:15:41 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
On Mon, Nov 21, 2016 at 11:57 AM, Laurent Rineau (CGAL/GeometryFactory) <> wrote:
There is an undocumented parameter that you may want to try... Add `facet_topology=CGAL::MANIFOLD,` in the parameters of `Mesh_criteria_3`, to enforce the manifoldness of the output. However, if mesh domain has not a manifold surface, the execution may loop and eventually crash. Use it carefully.
Laurent Rineau, PhD
Thanks for the advice, however, it seems that the non-manifoldness of the surface mesh is introduced somewhere in the optimization steps. Adding the manifold-parameter alone didn't help, but adding it together with "no_lloyd(), no_odt(), no_perturb(), no_exude()" produced a proper manifold mesh. Just exude alone also seems to be fine, still.
Best,
Patrick
- [cgal-discuss] make_mesh_3 results in non-manifold edges in surface mesh, Patrick, 11/20/2016
- Re: [cgal-discuss] make_mesh_3 results in non-manifold edges in surface mesh, Laurent Rineau (CGAL/GeometryFactory), 11/21/2016
- Re: [cgal-discuss] make_mesh_3 results in non-manifold edges in surface mesh, Patrick, 11/21/2016
