- To:
- Subject: Re: [cgal-discuss] Inconsistent point/convex hull distance computation values
- Date: Wed, 23 Nov 2016 10:36:08 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:kEwOmBTdAmP4FGfFplc0ZohQ59psv+yvbD5Q0YIujvd0So/mwa64ZBSN2/xhgRfzUJnB7Loc0qyN4vumAzJLuM/c+DBaKdoXCE9D0Z1X1yUbQ+e7SmTDZMbwaCI7GMkQHHRExFqcdXZvJcDlelfJqWez5zNBUj/2NA5yO/inUtWK15f/hKiO/MjYbAxMwTa8erhvNw6erAPLt8BQj5ExBLw2z06DmXZCcv9KxG5ubXaUhRf7+o/w05Nk9ilMoeMP/sVcVr/rPu5wGadcCy4nNHxz4cnDuhzKTA/J7XwZBDZF2iFUChTIuUmpFqz6tTH347Jw
On 11/22/2016 07:40 PM, SirM2X wrote:
Thanks a lot Sebastien. That was in fact the issue...
Just to confirm, the closest point that /closest_point_and_primitive/ call
gives me is the closest point ON the mesh, right? It's not giving me the
closest vertex or anything is it?
yes.
Thanks again
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Inconsistent-point-convex-hull-distance-computation-values-tp4662388p4662393.html
- [cgal-discuss] Inconsistent point/convex hull distance computation values, SirM2X, 11/22/2016
- Re: [cgal-discuss] Inconsistent point/convex hull distance computation values, Sebastien Loriot (GeometryFactory), 11/22/2016
- Re: [cgal-discuss] Inconsistent point/convex hull distance computation values, SirM2X, 11/22/2016
- Re: [cgal-discuss] Inconsistent point/convex hull distance computation values, Sebastien Loriot (GeometryFactory), 11/23/2016
