cgal-discuss - Re: [cgal-discuss] Intersection between Delaunay triangulations
  • To:
  • Subject: Re: [cgal-discuss] Intersection between Delaunay triangulations
  • Date: Sun, 27 Nov 2016 02:40:35 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:3ZGIXBRFgC8lgu4rCMda8c1qnNpsv+yvbD5Q0YIujvd0So/mwa64YBeN2/xhgRfzUJnB7Loc0qyN4vumAjdLuMfY+DBaKdoXCE9D0Z1X1yUbQ+e7SmTDZMbwaCI7GMkQHHRExFqcdXZvJcDlelfJqWez5zNBUj/2NA5yO/inUtWK15f/hKiP/YbOaVBImCaleuE1aw6nqB3Y8MgQm4prbKgrjQDYp2NBPOVQy2QvLl2am1Pw59y74YV4oBhX7vku/soFXaThdLkjVpRZCi4nOiY7/p7Frx7GGDeP53ITVS0zkx5BBQXZ8BayZZzxtirmqu5wwmHOIc33RL8zXC/5x6huQR7sziwAMmhqoynslsVsgfcD81qarBtlztuMbQ==
Hello!
   If you only want the intersection volume, and if both your meshes are convex, maybe converting each mesh to a convex hull, then to a polyhedron, and then to a Nef polyhedron might be faster, or at least simpler to code. I never tried to do so, though, and I have no idea how the Nef polyhedron cost scales with its complexity.
   In my case, I want to mesh each intersection between two cells, and so I have no other option than finding and constructing all intersections. In my code, the conversion to Nef polyhedra, intersection construction and meshing of ~650,000 intersections takes around ~4 minutes of CPU time, while the search takes ~30 seconds. The meshes, in this case, have each 600 elements / 200 nodes and 100,000 elements / 24,000 nodes.
   I'm not using CGAL's data structures, but it has a package to find the intersections between two sets of bounding boxes (see here). It could be useful in this situation.
Regards,
Thiago
2016-11-27 1:02 GMT+01:00 pbarletta <>:
Hi, thanks for the reply. Yes, its 3D, I forgot to mention that.
      I don't have the list of intersecting cells, I'd have to iterate over
every vertex of every cell of the *B* triangulation to find out if its
outside the  *A* triangulation, inside of it, or intersecting it; in which
case I would then convert to Nef Polyhedron.
      I'm dealing with triangulations of (2,000 - 20,000) points. How much
time did it take you to perform these volume calculations from the
intersections?
     Do you think it would be (easier/faster/possible) to just convert both
triangulations to Nef Polyhedrons and then calculate their intersection
spaces, to then calculate its volume?
Regards.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Intersection-between-Delaunay-triangulations-tp4662395p4662397.html
