- To: <>
- Subject: [cgal-discuss] CGAL header only installation usage
- Date: Mon, 16 Jan 2017 16:05:46 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
- Ironport-phdr: 9a23:6D7wYh8s49GN2v9uRHKM819IXTAuvvDOBiVQ1KB91uIcTK2v8tzYMVDF4r011RmSDNmdsK8P0ruN++C4ACpbvsbH6ChDOLV3FDY7yuwu1zQ6B8CEDUCpZNXLVAcdWPp4aVl+4nugOlJUEsutL3fbo3m18CJAUk6nbVk9ENz1G5XSjsK4ksnpqsGWO1wAxGPlOfIhDByzjQjYusQMr4pvLqp56hbArnZSM99dwnlpI13b31OlvobjtKJkpnBbtPslssJBSq7nZL8QTLpCDT1gPXpjt+PxshyWZA2N52AcVHheuBNODxnC9Bj2Xob4o2Ouv+x/2TKaO9CwR7kyVSWl965nSA7hmQ8MOiQ/tmrX3J8jxJlHqQ6s8kQsi7XfZ5uYYasmcw==
- Spamdiagnosticmetadata: NSPM
- Spamdiagnosticoutput: 1:99
Hi,
What is the exact way of running the examples after a header only
installation of CGAL. I installed CGAL using the header only way. Also if I
am using CGAL in a project of mine can I use CGAL the way Eigen is generally
used (since Eigen is always header only) i.e. can I just link the include
directory and will it work?
Best regards,
Anjishnu
- [cgal-discuss] CGAL header only installation usage, Anjishnu Bandyopadhyay, 01/16/2017
- Re: [cgal-discuss] CGAL header only installation usage, Laurent Rineau (CGAL/GeometryFactory), 01/16/2017
- Re: [cgal-discuss] CGAL header only installation usage, Anjishnu Bandyopadhyay, 01/16/2017
