- To:
- Subject: Re: [cgal-discuss] CGAL header only installation usage
- Date: Mon, 16 Jan 2017 16:47:06 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:+pQnWxY9usXdS+5ghGQPQaL/LSx+4OfEezUN459isYplN5qZrs67bnLW6fgltlLVR4KTs6sC0LuK9fu9EjVRsN6oizMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpTEdFQ/iOgVrO+/7BpDdj9it1+C15pbffxhEiCCzbL52Ixi6twvcu8kZjYd/Lqs8zgbCr2dVdehR2W5mP0+YkQzm5se38p5j8iBQtOwk+sVdT6j0fLk2QKJBAjg+PG87+MPktR/YTQuS/XQcSXkZkgBJAwfe8h73WIr6vzbguep83CmaOtD2TawxVD+/4apnVAPkhSEaPDM/7WrZiNF/jLhDrRyhuRJx3oDaboKSNPVwfKzdc9wVS2VdUctKSyxPH5mxY5cTA+cAI+pVqZT2qVsUrRu5AAmhHO3jxDlSiX/rx601zeIhER3b1wI8HtIOtmrbo8/oNKwPVey40qjGwCnFYf9N2Dny9o/IchU/rvGQR7JxccrfxlMzGAPZiVWQs4zkMzab2u8QtGWb6/BvVf+1i2E5rQFxviKjxt0tionPmI0a0E3E+D5lz4Y6P9K4TFR3Ydm+EJtfriyXMZZ9TM0lQ2Ftoik6y7sGtIancygF0psnwwTTa/udc4iH+h7jW/ieITB9hH17ZLK/nRaz8Ua6xeLgSsm010xKrypfntbQsXAN0hre4dWERPtl5kqs1jeC2xrO5u1YIU04j6XWJ4M7zrItmZcesFzPEyD3lUnskaObdUsp9vKn5unjeLnqu5GROoByhwrjKKohgNa/Dv49MgUWX2iU5+C81Lr78EHkWrlKi/o2n6javZzAIMQUvK+5AwtM3oYk9ha/Ey2q0NMGnXkHNl5FfgyIj5TxN1HPJvD3E+u/jkyjnTpq3fzKI6HtD5XXInXMjbvtZ6tx5kFdxQYryNBQ/ZNUCrUPIPLpXU/xscTVDhsjPAyp2eboFtN91p8EVWKVA6+ZNr3dvkWV5u80P+aMa5UauDLnJ/gi/f7ugmc1mUUBcqmxwZsXdHe4E+x6LEWWe3Xshs4NHnoLvgolUOPqlUaCUSVIanapX6M84yk7B5i8AYfCQICtmr2B0z2hEp1YfGAVQmyLRHznfoHBV/YXYz+JOedglCYFXP6vUdwPzxar4UXewqd9I+zIshcZs5/qyZA1zML6sVYd+DtxAtiHwk+ERH1zhHJJDXdi2Kliu0F71hGZ0K51iuFwHtNa47VOSAhsZs2U9PBzF92nAlGJRdyOUlvzGtg=
Le Monday, January 16, 2017 4:33:45 PM CET Anjishnu Bandyopadhyay a ?crit :
> Hi,
> Thanks. Maybe a stupid question but what does LINKED_WITH_TBB signify?
No, the question is not stupid, because we know the name of the macro is not
a good one: `CGAL_LINKED_WITH_TBB` tells the compiler that `<tbb.h>` can be
included. That macro is set by our CMake scripts when TBB is detected. And
the CMake scripts will also ensure that the produced binaries will be linked
with libtbb.
Actually, when I said:
> Yes, if you do not use our CMake scripts, there might be macros to define,
> such as
> -DCGAL_LINKED_WITH_TBB
> -DCGAL_USE_GMP
> -DCGAL_USE_MPFR
> -DCGAL_USE_ZLIB
> depending on which third-party libraries you use.
... I forgot to say that at link time the third-party libraries (such as
libgmp.so, libmpfr.so) must be linked with. Otherwise you will have link
errors.
Laurent Rineau, PhD
- [cgal-discuss] CGAL header only installation usage, Anjishnu Bandyopadhyay, 01/16/2017
- Re: [cgal-discuss] CGAL header only installation usage, Laurent Rineau (CGAL/GeometryFactory), 01/16/2017
- Re: [cgal-discuss] CGAL header only installation usage, Anjishnu Bandyopadhyay, 01/16/2017
