- To:
- Subject: Re: [cgal-discuss] CGAL header only installation usage
- Date: Mon, 16 Jan 2017 16:20:09 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Le Monday, January 16, 2017 4:05:46 PM CET Anjishnu Bandyopadhyay a ?crit :
> Hi,
> What is the exact way of running the examples after a header only
> installation of CGAL. I installed CGAL using the header only way. Also if
> I am using CGAL in a project of mine can I use CGAL the way Eigen is
> generally used (since Eigen is always header only) i.e. can I just link
> the include directory and will it work?
Yes, it should work similarly to Eigen.
Yes, if you do not use our CMake scripts, there might be macros to define,
such as
-DCGAL_LINKED_WITH_TBB
-DCGAL_USE_GMP
-DCGAL_USE_MPFR
-DCGAL_USE_ZLIB
depending on which third-party libraries you use.
Laurent Rineau, PhD
- [cgal-discuss] CGAL header only installation usage, Anjishnu Bandyopadhyay, 01/16/2017
- Re: [cgal-discuss] CGAL header only installation usage, Laurent Rineau (CGAL/GeometryFactory), 01/16/2017
- Re: [cgal-discuss] CGAL header only installation usage, Anjishnu Bandyopadhyay, 01/16/2017
