- To:
- Subject: [cgal-discuss] Conforming Delaunay Triangulation 2.5D
- Date: Thu, 6 Apr 2017 05:44:36 -0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
I saw the example using Delaunay Triangulation 2.5D and everything works fine.
Is it possible to use Conforming Delaunay Triangulation with CGAL::Projection_traits_xy_3?
I'm trying using this setup:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Projection_traits_xy_3<K> Gt;
typedef CGAL::Triangulation_vertex_base_with_info_2<std::string, Gt> Vb;
typedef CGAL::Constrained_triangulation_face_base_2<Gt> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb, Fb> TDS;
typedef CGAL::Exact_predicates_tag Itag;
typedef CGAL::Constrained_Delaunay_triangulation_2<K, TDS, Itag> CDT;
typedef K::Point_3 Point_CDT;
I can't insert a Point_3 on a CDT. I tried using CGAL::No_intersection_tag to avoid create new points with no success.
Is there a way to use Conforming Delaunay Triangulation 2.5D?
Renato Silveira
Ph.D. in Computer Science
Informatics Institute - UFRGS
Porto Alegre - RS - Brazil
- [cgal-discuss] Conforming Delaunay Triangulation 2.5D, Renato Silveira, 04/06/2017
- Message not available
- Re: [cgal-discuss] Conforming Delaunay Triangulation 2.5D, Pol Monsó Purtí, 04/06/2017
- Re: [cgal-discuss] Conforming Delaunay Triangulation 2.5D, Renato Silveira, 04/07/2017
