- To:
- Subject: Re: [cgal-discuss] Conforming Delaunay Triangulation 2.5D
- Date: Thu, 6 Apr 2017 23:05:11 -0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Thank you!!!!
On Thu, Apr 6, 2017 at 7:26 AM, Pol Monsó Purtí <> wrote:
You have to use Gt instead of K on the cdt typedef
typedef CGAL::Constrained_Delaunay_triangulation_2<Gt, TDS, Itag> CDT;I had trouble getting it to work thought with the exact tag. Use CDT::Point to get the point, its less error-prone.Cheers and gl!El dia 06/04/2017 11:39, "Pol M" <> va escriure:You have to use Gt instead of K on the cdt typedef
typedef CGAL::Constrained_Delaunay_triangulation_2<Gt, TDS, Itag> CDT;I had trouble getting it to work thought with the exact tag. Use CDT::Point to get the point, its less error-prone.Cheers and gl!El dia 06/04/2017 10:46, "Renato Silveira" <> va escriure:I saw the example using Delaunay Triangulation 2.5D and everything works fine.Is it possible to use Conforming Delaunay Triangulation with CGAL::Projection_traits_xy_3?I'm trying using this setup:typedef CGAL::Exact_predicates_inexact_constructions_kernel K;typedef CGAL::Projection_traits_xy_3<K> Gt;typedef CGAL::Triangulation_vertex_base_with_info_2<std::string, Gt> Vb;typedef CGAL::Constrained_triangulation_face_base_2<Gt> Fb;typedef CGAL::Triangulation_data_structure_2<Vb, Fb> TDS;typedef CGAL::Exact_predicates_tag Itag;typedef CGAL::Constrained_Delaunay_triangulation_2<K, TDS, Itag> CDT;typedef K::Point_3 Point_CDT;I can't insert a Point_3 on a CDT. I tried using CGAL::No_intersection_tag to avoid create new points with no success.Is there a way to use Conforming Delaunay Triangulation 2.5D?--Renato SilveiraPh.D. in Computer Science
Informatics Institute - UFRGS
Porto Alegre - RS - Brazil
Renato Silveira
- [cgal-discuss] Conforming Delaunay Triangulation 2.5D, Renato Silveira, 04/06/2017
- Message not available
- Re: [cgal-discuss] Conforming Delaunay Triangulation 2.5D, Pol Monsó Purtí, 04/06/2017
- Re: [cgal-discuss] Conforming Delaunay Triangulation 2.5D, Renato Silveira, 04/07/2017
