- To:
- Subject: Re: [cgal-discuss] Triangulation of points in a 4D Sphere
- Date: Fri, 5 May 2017 03:34:04 -0700 (PDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23: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
>Your code works fine on my machine. Are you sure it is crashing inside this
piece of code?
Really? Every time? Strange. And yes, I am sure that it is crashing there,
on the insert.
>"array_convex_hull_2.exe"? Is it normal? Are you launching the right
executable?
Yeah, I used the example projects as base to test something, so that I
wouldn't have to set everything up, and never got around to set it up
properly. It is the right executable.
Huh... hell, could it be something wrong with the libgmp-10.dll? Maybe I
have an old version or something like that?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Triangulation-of-points-in-a-4D-Sphere-tp4662712p4662714.html
- [cgal-discuss] Triangulation of points in a 4D Sphere, GSBicalho, 05/05/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, Clément Jamin, 05/05/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, GSBicalho, 05/05/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, Clément Jamin, 05/06/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, GSBicalho, 05/09/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, Clément Jamin, 05/12/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, GSBicalho, 05/12/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, Clément Jamin, 05/15/2017
