- To:
- Subject: Re: [cgal-discuss] Triangulation of points in a 4D Sphere
- Date: Sat, 6 May 2017 23:43:34 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi,
Can you give some details abour your platform? 32 or 64 bits? VC++ version? Etc.
Clément.
On Fri, May 5, 2017 at 12:34 PM, GSBicalho <> wrote:
>Your code works fine on my machine. Are you sure it is crashing inside this
piece of code?
Really? Every time? Strange. And yes, I am sure that it is crashing there,
on the insert.
>"array_convex_hull_2.exe"? Is it normal? Are you launching the right
executable?
Yeah, I used the example projects as base to test something, so that I
wouldn't have to set everything up, and never got around to set it up
properly. It is the right executable.
Huh... hell, could it be something wrong with the libgmp-10.dll? Maybe I
have an old version or something like that?
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Triangulation-of-points-in-a-4D-Sphere-tp4662712p4662714.html
- [cgal-discuss] Triangulation of points in a 4D Sphere, GSBicalho, 05/05/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, Clément Jamin, 05/05/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, GSBicalho, 05/05/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, Clément Jamin, 05/06/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, GSBicalho, 05/09/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, Clément Jamin, 05/12/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, GSBicalho, 05/12/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, Clément Jamin, 05/15/2017
