- To:
- Subject: Re: [cgal-discuss] Triangulation of points in a 4D Sphere
- Date: Fri, 12 May 2017 07:26:19 -0700 (PDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23: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
I've tried, however, even though it is configured exactly like the 32bit
version, it gives me the following linking error:
---ERROR---
1>------ Build started: Project: CGAL_Core, Configuration: Release x64
1> Creating library
C:/dev/CGAL-4.9.1/build_x64/lib/Release/CGAL_Core-vc140-mt-4.9.1.lib and
object C:/dev/CGAL-4.9.1/build_x64/lib/Release/CGAL_Core-vc140-mt-4.9.1.exp
1>all_files.obj : error LNK2019: unresolved external symbol
__imp___gmp_randinit referenced in function "struct __gmp_randstate_struct
(* __cdecl CORE::getRandstate(void))[1]"
(?getRandstate@CORE@@YAPEAY00U__gmp_randstate_struct@@XZ)
1>all_files.obj : error LNK2019: unresolved external symbol __imp___gmpz_add
referenced in function "public: __cdecl
CORE::BigFloatRep::BigFloatRep(double)" (??0BigFloatRep@CORE@@QEAA@N@Z)
__imp___gmpz_add_ui referenced in function "public: class CORE::BigInt
__cdecl CORE::BigInt::operator++(int)" (??EBigInt@CORE@@QEAA?AV01@H@Z)
1>all_files.obj : error LNK2019: unresolved external symbol __imp___gmpz_and
referenced in function "public: class CORE::BigInt & __cdecl
CORE::BigInt::operator&=(class CORE::BigInt const &)"
(??_4BigInt@CORE@@QEAAAEAV01@AEBV01@@Z)
__imp___gmpz_clear referenced in function "class CORE::BigFloat __cdecl
CORE::content<class CORE::BigFloat>(class CORE::Polynomial<class
CORE::BigFloat> const &)"
(??$content@VBigFloat@CORE@@@CORE@@YA?AVBigFloat@0@AEBV?$Polynomial@VBigFloat@CORE@@@0@@Z)
1>all_files.obj : error LNK2019: unresolved external symbol __imp___gmpz_cmp
referenced in function "class CORE::BigInt __cdecl CORE::content<class
CORE::BigInt>(class CORE::Polynomial<class CORE::BigInt> const &)"
(??$content@VBigInt@CORE@@@CORE@@YA?AVBigInt@0@AEBV?$Polynomial@VBigInt@CORE@@@0@@Z)
__imp___gmpz_divexact referenced in function "class CORE::BigInt __cdecl
CORE::div_exact(class CORE::BigInt const &,class CORE::BigInt const &)"
(?div_exact@CORE@@YA?AVBigInt@1@AEBV21@0@Z)
__imp___gmpz_divisible_p referenced in function "bool __cdecl
CORE::isDivisible(class CORE::BigFloat const &,class CORE::BigFloat const
&)" (?isDivisible@CORE@@YA_NAEBVBigFloat@1@0@Z)
1>all_files.obj : error LNK2019: unresolved external symbol __imp___gmpz_gcd
referenced in function "class CORE::BigInt __cdecl CORE::gcd(class
(?gcd@CORE@@YA?AVBigInt@1@AEBV21@0@Z)
__imp___gmpz_get_d referenced in function "public: virtual double __cdecl
CORE::Realbase_for<class CORE::BigInt>::doubleValue(void)const "
(?doubleValue@?$Realbase_for@VBigInt@CORE@@@CORE@@UEBANXZ)
__imp___gmpz_get_si referenced in function "public: int __cdecl
CORE::BigInt::intValue(void)const " (?intValue@BigInt@CORE@@QEBAHXZ)
__imp___gmpz_get_str referenced in function "public: virtual class
std::basic_ostream<char,struct std::char_traits<char> > & __cdecl
CORE::Realbase_for<class CORE::BigInt>::operator<<(class
std::basic_ostream<char,struct std::char_traits<char> > &)const "
(??6?$Realbase_for@VBigInt@CORE@@@CORE@@UEBAAEAV?$basic_ostream@DU?$char_traits@D@std@@@std@@AEAV23@@Z)
__imp___gmpz_init referenced in function "public: __cdecl CORE::Sturm<class
CORE::BigInt>::Sturm<class CORE::BigInt>(class CORE::Polynomial<class
CORE::BigInt>)"
(??0?$Sturm@VBigInt@CORE@@@CORE@@QEAA@V?$Polynomial@VBigInt@CORE@@@1@@Z)
__imp___gmpz_init_set referenced in function "public: __cdecl
CORE::BigInt::BigInt(struct __mpz_struct const *)"
(??0BigInt@CORE@@QEAA@PEBU__mpz_struct@@@Z)
__imp___gmpz_init_set_d referenced in function "public: __cdecl
CORE::BigInt::BigInt(float)" (??0BigInt@CORE@@QEAA@M@Z)
__imp___gmpz_init_set_si referenced in function "class CORE::BigFloat
__cdecl CORE::content<class CORE::BigFloat>(class CORE::Polynomial<class
__imp___gmpz_init_set_str referenced in function "public: __cdecl
CORE::BigFloat::BigFloat(class std::basic_string<char,struct
std::char_traits<char>,class std::allocator<char> > const &)"
(??0BigFloat@CORE@@QEAA@AEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z)
__imp___gmpz_init_set_ui referenced in function "public: __cdecl
CORE::BigInt::BigInt(unsigned char)" (??0BigInt@CORE@@QEAA@E@Z)
1>all_files.obj : error LNK2019: unresolved external symbol __imp___gmpz_ior
CORE::BigInt::operator|=(class CORE::BigInt const &)"
(??_5BigInt@CORE@@QEAAAEAV01@AEBV01@@Z)
1>all_files.obj : error LNK2019: unresolved external symbol __imp___gmpz_mul
referenced in function "class CORE::Polynomial<class CORE::BigInt> __cdecl
CORE::gcd<class CORE::BigInt>(class CORE::Polynomial<class CORE::BigInt>
const &,class CORE::Polynomial<class CORE::BigInt> const &)"
(??$gcd@VBigInt@CORE@@@CORE@@YA?AV?$Polynomial@VBigInt@CORE@@@0@AEBV10@0@Z)
__imp___gmpz_mul_2exp referenced in function "public: __cdecl
__imp___gmpz_pow_ui referenced in function "public: class CORE::BigFloat
__cdecl CORE::Polynomial<class CORE::BigFloat>::sepBound(void)const "
(?sepBound@?$Polynomial@VBigFloat@CORE@@@CORE@@QEBA?AVBigFloat@2@XZ)
__imp___gmpz_remove referenced in function "public: virtual void __cdecl
CORE::Realbase_for<class CORE::BigInt>::ULV_E(class CORE::extLong &,class
CORE::extLong &,class CORE::extLong &,class CORE::extLong &,class
CORE::extLong &,class CORE::extLong &)const "
(?ULV_E@?$Realbase_for@VBigInt@CORE@@@CORE@@UEBAXAEAVextLong@2@00000@Z)
__imp___gmpz_scan1 referenced in function "public: virtual void __cdecl
CORE::Realbase_for<double>::ULV_E(class CORE::extLong &,class CORE::extLong
&,class CORE::extLong &,class CORE::extLong &,class CORE::extLong &,class
(?ULV_E@?$Realbase_for@N@CORE@@UEBAXAEAVextLong@2@00000@Z)
1>all_files.obj : error LNK2019: unresolved external symbol __imp___gmpz_set
referenced in function "public: __cdecl CORE::BigRatRep::BigRatRep(struct
__mpz_struct const *,struct __mpz_struct const *)"
(??0BigRatRep@CORE@@QEAA@PEBU__mpz_struct@@0@Z)
__imp___gmpz_set_str referenced in function "class
std::basic_istream<char,struct std::char_traits<char> > & __cdecl
CORE::io_read(class std::basic_istream<char,struct std::char_traits<char>
> &,struct __mpz_struct *)"
(?io_read@CORE@@YAAEAV?$basic_istream@DU?$char_traits@D@std@@@std@@AEAV23@PEAU__mpz_struct@@@Z)
__imp___gmpz_set_ui referenced in function "class
__imp___gmpz_sizeinbase referenced in function "public: __cdecl
CORE::Realbase_for<class CORE::BigInt>::Realbase_for<class
CORE::BigInt>(class CORE::BigInt const &)"
(??0?$Realbase_for@VBigInt@CORE@@@CORE@@QEAA@AEBVBigInt@1@@Z)
1>all_files.obj : error LNK2019: unresolved external symbol __imp___gmpz_sub
referenced in function "class CORE::BigInt __cdecl CORE::operator-(class
(??GCORE@@YA?AVBigInt@0@AEBV10@0@Z)
__imp___gmpz_sub_ui referenced in function "public: class CORE::BigInt
__cdecl CORE::BigInt::operator--(int)" (??FBigInt@CORE@@QEAA?AV01@H@Z)
__imp___gmpz_tdiv_q referenced in function "public: class CORE::BigInt &
__cdecl CORE::BigInt::operator/=(class CORE::BigInt const &)"
(??_0BigInt@CORE@@QEAAAEAV01@AEBV01@@Z)
__imp___gmpz_tdiv_q_2exp referenced in function "class CORE::BigInt __cdecl
CORE::operator>>(class CORE::BigInt const &,unsigned long)"
(??5CORE@@YA?AVBigInt@0@AEBV10@K@Z)
__imp___gmpz_tdiv_qr referenced in function "public: void __cdecl
CORE::BigFloatRep::div(class CORE::BigFloatRep const &,class
CORE::BigFloatRep const &,class CORE::extLong const &)"
(?div@BigFloatRep@CORE@@QEAAXAEBV12@0AEBVextLong@2@@Z)
__imp___gmpz_tdiv_r referenced in function "class CORE::BigInt __cdecl
CORE::operator%(class CORE::BigInt const &,class CORE::BigInt const &)"
(??LCORE@@YA?AVBigInt@0@AEBV10@0@Z)
1>all_files.obj : error LNK2019: unresolved external symbol __imp___gmpz_xor
CORE::BigInt::operator^=(class CORE::BigInt const &)"
(??_6BigInt@CORE@@QEAAAEAV01@AEBV01@@Z)
1>all_files.obj : error LNK2019: unresolved external symbol __imp___gmpq_add
referenced in function "public: class CORE::BigRat __cdecl
CORE::Polynomial<class CORE::BigRat>::eval<class CORE::BigFloat>(class
CORE::BigFloat const &)const "
(??$eval@VBigFloat@CORE@@@?$Polynomial@VBigRat@CORE@@@CORE@@QEBA?AVBigRat@1@AEBVBigFloat@1@@Z)
__imp___gmpq_canonicalize referenced in function "public: __cdecl
CORE::BigRatRep::BigRatRep(struct __mpz_struct const *,struct __mpz_struct
const *)" (??0BigRatRep@CORE@@QEAA@PEBU__mpz_struct@@0@Z)
__imp___gmpq_clear referenced in function "class CORE::BigRat __cdecl
CORE::content<class CORE::BigRat>(class CORE::Polynomial<class CORE::BigRat>
const &)"
(??$content@VBigRat@CORE@@@CORE@@YA?AVBigRat@0@AEBV?$Polynomial@VBigRat@CORE@@@0@@Z)
1>all_files.obj : error LNK2019: unresolved external symbol __imp___gmpq_cmp
referenced in function "class CORE::BigRat __cdecl CORE::content<class
CORE::BigRat>(class CORE::Polynomial<class CORE::BigRat> const &)"
1>all_files.obj : error LNK2019: unresolved external symbol __imp___gmpq_div
referenced in function "class CORE::BigRat __cdecl CORE::operator/(class
CORE::BigRat const &,class CORE::BigRat const &)"
(??KCORE@@YA?AVBigRat@0@AEBV10@0@Z)
__imp___gmpq_get_d referenced in function "public: virtual double __cdecl
CORE::Realbase_for<class CORE::BigRat>::doubleValue(void)const "
(?doubleValue@?$Realbase_for@VBigRat@CORE@@@CORE@@UEBANXZ)
__imp___gmpq_get_str referenced in function "public: class
std::basic_string<char,struct std::char_traits<char>,class
std::allocator<char> > __cdecl CORE::BigRat::get_str(int)const "
(?get_str@BigRat@CORE@@QEBA?AV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@H@Z)
__imp___gmpq_init referenced in function "public: __cdecl
CORE::BigRat::BigRat(class CORE::BigFloat const &)"
(??0BigRat@CORE@@QEAA@AEBVBigFloat@1@@Z)
1>all_files.obj : error LNK2019: unresolved external symbol __imp___gmpq_mul
1>all_files.obj : error LNK2019: unresolved external symbol __imp___gmpq_set
referenced in function "public: __cdecl CORE::BigRatRep::BigRatRep(class
CORE::BigRatRep const &)" (??0BigRatRep@CORE@@QEAA@AEBV01@@Z)
__imp___gmpq_set_d referenced in function "public: __cdecl
CORE::BigRat::BigRat(double)" (??0BigRat@CORE@@QEAA@N@Z)
__imp___gmpq_set_si referenced in function "public: __cdecl
CORE::BigRat::BigRat(int)" (??0BigRat@CORE@@QEAA@H@Z)
__imp___gmpq_set_str referenced in function "public: __cdecl
CORE::BigRat::BigRat(char const *)" (??0BigRat@CORE@@QEAA@PEBD@Z)
__imp___gmpq_set_z referenced in function "public: __cdecl
CORE::BigRat::BigRat(class CORE::BigInt const &)"
(??0BigRat@CORE@@QEAA@AEBVBigInt@1@@Z)
1>all_files.obj : error LNK2019: unresolved external symbol __imp___gmpq_sub
referenced in function "class CORE::BigRat __cdecl CORE::operator-(class
(??GCORE@@YA?AVBigRat@0@AEBV10@0@Z)
1>..\..\..\auxiliary\gmp\lib\libmpfr-4.lib : warning LNK4272: library
machine type 'X86' conflicts with target machine type 'x64'
1>..\..\..\auxiliary\gmp\lib\libgmp-10.lib : warning LNK4272: library
1>C:\dev\CGAL-4.9.1\build_x64\bin\Release\CGAL_Core-vc140-mt-4.9.1.dll :
fatal error LNK1120: 50 unresolved externals
1>Done building project "CGAL_Core.vcxproj" -- FAILED.
I'd guess that this happens because the "libgmp-10.dll" and "libmpfr-4.dll"
are in 32bits, and I can't find 64bits versions of them.
Now I've managed to compile and run the program on Linux, and it works
perfectly, but I'd still like to get it working on Windows.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Triangulation-of-points-in-a-4D-Sphere-tp4662712p4662724.html
- [cgal-discuss] Triangulation of points in a 4D Sphere, GSBicalho, 05/05/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, Clément Jamin, 05/05/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, GSBicalho, 05/05/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, Clément Jamin, 05/06/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, GSBicalho, 05/09/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, Clément Jamin, 05/12/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, GSBicalho, 05/12/2017
- Re: [cgal-discuss] Triangulation of points in a 4D Sphere, Clément Jamin, 05/15/2017
