- To:
- Subject: Re: [cgal-discuss] Error in: faces_around_face() with CGAL::Surface_Mesh
- Date: Fri, 2 Jun 2017 07:17:20 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
The iterator also goes over border halfedges so you might get some
invalid faces for those. You can filter them using is_border(f,mesh).
Sebastien.
On 06/01/2017 08:37 PM, hossan.nazmul wrote:
Hello Everyone,
I am getting an error in CGAL::faces_around_face. for example, I have five
points(p0,p1,p2,p3,p4)I have four faces (f0,f1,f2,f3). I used
CGAL::Surface_Mesh to store these vertices and faces. (See the attached
example code). I can query on the Surface_Mesh. for example,
vertices_around_faces, vertices_around_vertex.
Here is my code: main.cpp
<http://cgal-discuss.949826.n4.nabble.com/file/n4662744/main.cpp>
Problem:
1. Now I would like to find the adjacent faces(?) (faces around face) of a
specific face but I get some wired faces. If I try to see the
vertices_around_face() that the program throws an error? (CGAL Error:
Assertion Violation!). did I miss something? or it's a CGAL error? (if you
run my example code you will see it)
2. How to calculate the intersection of three faces?
Thanks in advance!
Best,
Nazmul
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Error-in-faces-around-face-with-CGAL-Surface-Mesh-tp4662744.html
- [cgal-discuss] Error in: faces_around_face() with CGAL::Surface_Mesh, hossan.nazmul, 06/01/2017
- Re: [cgal-discuss] Error in: faces_around_face() with CGAL::Surface_Mesh, Sebastien Loriot (GeometryFactory), 06/02/2017
- Re: [cgal-discuss] Error in: faces_around_face() with CGAL::Surface_Mesh, hossan.nazmul, 06/06/2017
- Re: [cgal-discuss] Error in: faces_around_face() with CGAL::Surface_Mesh, Sebastien Loriot (GeometryFactory), 06/07/2017
- Re: [cgal-discuss] Error in: faces_around_face() with CGAL::Surface_Mesh, hossan.nazmul, 06/08/2017
- Re: [cgal-discuss] Error in: faces_around_face() with CGAL::Surface_Mesh, Sebastien Loriot (GeometryFactory), 06/12/2017
