cgal-discuss - Re: [cgal-discuss] Error in: faces_around_face() with CGAL::Surface_Mesh
  • To:
  • Subject: Re: [cgal-discuss] Error in: faces_around_face() with CGAL::Surface_Mesh
  • Date: Wed, 7 Jun 2017 08:04:58 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
On 06/06/2017 12:56 PM, hossan.nazmul wrote:
Hello Sebastien,
I couldn't find the way to filter faces_around_faces using is_border(f,mesh)
function? Could you please give an example? Thanks in Advance!
Nazmul
Graph g;
typedef boost::graph_traits<Graph>::face_descriptor face_descriptor;
face_descriptor f = ...
BOOST_FOREACH(face_descriptor faf, faces_around_face(f,g))
if ( faf == boost::graph_traits<Graph>::null_face())
continue;
/// process faf
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Error-in-faces-around-face-with-CGAL-Surface-Mesh-tp4662744p4662746.html
