cgal-discuss - Re: [cgal-discuss] Error in: faces_around_face() with CGAL::Surface_Mesh
  • To:
  • Subject: Re: [cgal-discuss] Error in: faces_around_face() with CGAL::Surface_Mesh
  • Date: Mon, 12 Jun 2017 08:56:04 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:AyB5URbqlfdTW2UaJLsjEKD/LSx+4OfEezUN459isYplN5qZr8u5bnLW6fgltlLVR4KTs6sC0LuJ9fi4EUU7or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6arXK99yMdFQviPgRpOOv1BpTSj8Oq3Oyu5pHfeQtFiT6/bL9oMBm6sRjau9ULj4dlNqs/0AbCrGFSe+RRy2NoJFaTkAj568yt4pNt8Dletuw4+cJYXqr0Y6o3TbpDDDQ7KG81/9HktQPCTQSU+HQRVHgdnwdSDAjE6BH6WYrxsjf/u+Fg1iSWIdH6QLYpUjmk8qxlSgLniD0fOjAk7m/XhMx+jKVYrhyvqRNwzIzbb52aOvdlYqPQf8kXSXZdUstfVyFMBJ63YYsVD+oGOOZVt4fxqUYQohSlHwasH//vyj5WiX/wwKY01eMhERvH3AwnA9IFrXDYotTrO6cVVOC60rXIzS/Dbv1Wwzjy9JTIchc7ofCMWL58f9faxE40FwPBiVWQs43lPzSJ1ugXtmib6/FtVe2qi2E9qgFxpiKjydsrionMn48YzE3P+yt+wIYwP9K4SUh7bMaiEJRKrC6VLI92Td04T250vyY6z6UKtoK0fCcQzJQr3Rnfa+aIc4WO/xntV/6RLC9miH55fL+znRW//Ei6xuHhSMW500xGojdGn9XQrnwA1R/e5tKZRvZy/0qtwyuD2gTd5+1eI005lazWIIM7zLEqjJocq0HDEzf2mEroiK+WcV0p+u2y5OTmZrXqv5GdN5Vohg3nPKQih8+yDfgiPggBWGib/uu81Ln98kHjXLpKifg2nrHYsJDcO8sbura0DxFJ3osn8RqyDDer3M4FkXUZL19JYg+Lgov1N13WJfD3F/a/g1CikDdxwPDGO6XsAo7JLnjEirfhfLF961JGxAo2ydBS/J1UCrQbL/LyXk/9rsDXDhg8MwCs2eboFM191p8CWWKIGqKWLKzSvkWM5u42PuaMZZQVtyrgK/g+/P7jlmQ5mF8Yfamxx5QbcnG4HvJ8I0WYe3XgmNkBEX1Z9jY5GeflgVnHXT9IbGupRIo94Cs6AcSoF9TtXIeo1fa60S2yBYFXa2YOLleWEHD0P8WrVvAJZT6IM+FomSADT6ngAcd1zhWprg791/xiKsLb/yQZsdTo090jtL6brg076TEhV5fV6GqKVWwhxm4=
See this example:
http://doc.cgal.org/latest/AABB_tree/AABB_tree_2AABB_face_graph_triangle_example_8cpp-example.html
You can replace Polyhedron_3 by Surface_mesh in the example.
Sebastien.
On 06/08/2017 10:59 AM, hossan.nazmul wrote:
Hello Sebastien,
Thanks for your help. It worked for me. As I am new to CGAL and have no
extensive knowledge in C++, I don't understand a lot of concept.
I am now trying to find the intersection of three or more faces. I couldn't
find any function in Surface_Mesh to do so. Could you please help me to find
the way to compute the intersection of three or more faces. Is it possible
to do with Surface_Mesh?
Thanks,
Nazmul
NOTE: I would like to find the point of intersection (corner point) where
three or more faces meet. (an example if possible) [please see my program:
main.txt <http://cgal-discuss.949826.n4.nabble.com/file/n4662753/main.txt>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Error-in-faces-around-face-with-CGAL-Surface-Mesh-tp4662744p4662753.html
