- To:
- Subject: [cgal-discuss] QP Solver taking too long
- Date: Mon, 10 Jul 2017 13:21:07 -0700 (PDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23: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
Should a problem with an m=914 n=616, r= 600 ish be taking over 10 minutes to
solve? I can only get the vout to show me the text if i f10-f11 over them (
I am using microsoft visual studio 2015 running on windows 10). I am using
MP_Float for the ET, btw if that is bad please let me know. My program is
using these typedef
I am using CGAL 4.10 x64.
typedef Quadratic_program<double> Program;
typedef CGAL::MP_Float ET;
typedef Quadratic_program_solution<ET> Solution;
Thank you very much for your help in advance!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/QP-Solver-taking-too-long-tp4662817.html
- [cgal-discuss] QP Solver taking too long, thisisatest, 07/10/2017
