cgal-discuss - Re: [cgal-discuss] compile demo in ubuntu
  • To:
  • Subject: Re: [cgal-discuss] compile demo in ubuntu
  • Date: Wed, 12 Jul 2017 08:25:41 -0700 (PDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
  • Ironport-phdr: 9a23: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
i set variable as you said but it didn't work
when i check variable (printenv) i didn't see it between variables
and maybe i should tell you i had to set QT_PLUGIN_PATH:
export QT_PLUGIN_PATH=/usr/lib/x86_64-linux-gnu/qt5/plugins
otherwise i got this error:
This application failed to start because it could not find or load the Qt
platform plugin "xcb"
in "".
Reinstalling the application may fix this problem.
Aborted (core dumped)
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/compile-demo-in-ubuntu-tp4662810p4662824.html
