cgal-discuss - Re: [cgal-discuss] compile demo in ubuntu
  • To:
  • Subject: Re: [cgal-discuss] compile demo in ubuntu
  • Date: Tue, 11 Jul 2017 10:40:07 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Le Monday, July 10, 2017 7:27:38 PM CEST Servenaz a ?crit :
> make CGAL_Qt5 work without error
> how could i check the version ?
> and finally how could i compile demo?
> thanks a lot for your consideration
And when you try to configure the demo/Alpha_sphape_3/ with CMake, do you
still have the following message?
-- NOTICE: The CGAL_Qt5 library seems to be required but is not build. Thus,
it is expected that some executables will not be compiled.
Make sure the variable CGAL_DIR in demo/Alpha_sphape_3/CMakeCache.txt points
to something in /home/pc/src/CGAL-4.10/ and not to another version of CGAL
that may be installed elsewhere on your machine.
Laurent Rineau, PhD
