- To:
- Subject: Re: [cgal-discuss] 3D Mesh: Vertices not referenced by triangles or tetrahedra
- Date: Sat, 5 Aug 2017 22:35:46 +0530
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi
It will better if generated data save in mesh instead Medit format. It seems to saving issue notĀ CGAL 3D Meshing procedure. On Sat, Aug 5, 2017 at 7:14 PM, Michael Bieri <> wrote:
Hi all,I generate a rather complicated mesh and save it in the Medit format. When I load the mesh, I observe that some vertices are never referenced, neither by the list of "Triangles" nor "Tetrahedra".I generated various meshes up to 200'000 vertices, where that behavior never occured. Now I have a mesh of 1'000'000 vertices where it happens.Could this be a bug in CGAL 3D Meshing or is it a normal behavior? Can I savely drop the unreferenced vertices?Best regards,Michael
thanks and regardsĀ
mobile:9163016823
- [cgal-discuss] 3D Mesh: Vertices not referenced by triangles or tetrahedra, Michael Bieri, 08/05/2017
- Re: [cgal-discuss] 3D Mesh: Vertices not referenced by triangles or tetrahedra, Biswajit Biswas, 08/05/2017
