- To:
- Subject: [cgal-discuss] CGAL 4.8.2 boost 1.6.2 msvc2015 error running empty main()
- Date: Mon, 7 Aug 2017 03:36:41 -0700 (PDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Neutral ; spf=None
- Ironport-phdr: 9a23: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
Does anyone know what can be the reason for these errors I am getting?
I have compiled and build different versions of CGAL including: 4.10 4.9 and
4.8.2 with Qt5.6.2 and Boost 1.6.2 and 1.6.4 for MSVC2015 x64 and I program
in Release.
I include the CGAL and Boost directories and files in MSVC as in this image:
<http://cgal-discuss.949826.n4.nabble.com/file/n4662887/Untitled-8.jpg>
When I try to run an empty main with an #include:
#include <iostream>
int main()
return 0;
I get the following errors:
1>------ Rebuild All started: Project: ConsoleApplication1, Configuration:
Release x64 ------
1> Source.cpp
1>C:\Program Files (x86)\Microsoft Visual Studio
14.0\VC\include\xmemory(18): error C2988: unrecognizable template
declaration/definition
14.0\VC\include\xmemory(18): error C2143: syntax error: missing ';' before
14.0\VC\include\xmemory(18): error C2433: 'pair': 'inline' not permitted on
data declarations
14.0\VC\include\xmemory(18): error C4430: missing type specifier - int
assumed. Note: C++ does not support default-int
14.0\VC\include\xmemory(18): error C2059: syntax error: '<'
14.0\VC\include\xmemory(38): error C2143: syntax error: missing ';' before
14.0\VC\include\xmemory(38): error C2447: '{': missing function header
(old-style formal list?)
14.0\VC\include\xmemory(46): error C2061: syntax error: identifier
'_General_ptr_iterator_tag'
14.0\VC\include\xmemory(64): error C2061: syntax error: identifier
'_Really_trivial_ptr_iterator_tag'
14.0\VC\include\xmemory(67): error C2995: '_FwdIt
std::_Uninitialized_copy_unchecked1(_InIt,_InIt,_FwdIt)': function template
has already been defined
1> C:\Program Files (x86)\Microsoft Visual Studio
14.0\VC\include\xmemory(45): note: see declaration of
'std::_Uninitialized_copy_unchecked1'
14.0\VC\include\xmemory(81): error C2061: syntax error: identifier
'input_iterator_tag'
14.0\VC\include\xmemory(90): error C2061: syntax error: identifier
'random_access_iterator_tag'
14.0\VC\include\xmemory(95): error C2995: '_FwdIt
std::_Uninitialized_copy1(_InIt,_InIt,_FwdIt)': function template has
14.0\VC\include\xmemory(80): note: see declaration of
'std::_Uninitialized_copy1'
14.0\VC\include\xmemory(126): error C2061: syntax error: identifier
14.0\VC\include\xmemory(145): error C2061: syntax error: identifier
14.0\VC\include\xmemory(150): error C2995: '_FwdIt
std::_Uninitialized_copy_n_unchecked1(_InIt,_Diff,_FwdIt)': function
template has already been defined
14.0\VC\include\xmemory(125): note: see declaration of
'std::_Uninitialized_copy_n_unchecked1'
14.0\VC\include\xmemory(219): error C2061: syntax error: identifier
'_Wrap_alloc'
14.0\VC\include\xmemory(238): error C2061: syntax error: identifier
'_Wrap_alloc'
14.0\VC\include\xmemory(247): error C2061: syntax error: identifier
'_Wrap_alloc'
14.0\VC\include\xmemory(258): error C2061: syntax error: identifier
'_Wrap_alloc'
14.0\VC\include\xmemory(272): error C2061: syntax error: identifier
'_Wrap_alloc'
14.0\VC\include\xmemory(291): error C2061: syntax error: identifier
'_Wrap_alloc'
14.0\VC\include\xmemory(300): error C2061: syntax error: identifier
'_Wrap_alloc'
14.0\VC\include\xmemory(312): error C2061: syntax error: identifier
'_Wrap_alloc'
14.0\VC\include\xmemory(414): error C4430: missing type specifier - int
14.0\VC\include\xmemory(414): error C2988: unrecognizable template
14.0\VC\include\xmemory(414): error C2143: syntax error: missing ',' before
14.0\VC\include\xmemory(431): error C4430: missing type specifier - int
14.0\VC\include\xmemory(431): error C2988: unrecognizable template
14.0\VC\include\xmemory(431): error C2143: syntax error: missing ',' before
14.0\VC\include\xmemory(435): error C2995: 'void
std::_Uninit_alloc_fill_n1(_FwdIt,_Diff,const int)': function template has
14.0\VC\include\xmemory(414): note: see declaration of
'std::_Uninit_alloc_fill_n1'
14.0\VC\include\xmemory(441): error C4430: missing type specifier - int
14.0\VC\include\xmemory(441): error C2988: unrecognizable template
14.0\VC\include\xmemory(441): error C2143: syntax error: missing ',' before
14.0\VC\include\xmemory(452): error C2061: syntax error: identifier
'_Wrap_alloc'
14.0\VC\include\xmemory(469): error C2061: syntax error: identifier
'_Wrap_alloc'
14.0\VC\include\xmemory(472): error C2995: 'void
std::_Uninitialized_default_fill_n1(_FwdIt,_Diff)': function template has
14.0\VC\include\xmemory(451): note: see declaration of
'std::_Uninitialized_default_fill_n1'
14.0\VC\include\xmemory(478): error C2061: syntax error: identifier
'_Wrap_alloc'
14.0\VC\include\algorithm(22): error C2988: unrecognizable template
14.0\VC\include\algorithm(22): error C2143: syntax error: missing ';' before
14.0\VC\include\algorithm(22): error C2433: 'pair': 'inline' not permitted
on data declarations
14.0\VC\include\algorithm(22): error C4430: missing type specifier - int
14.0\VC\include\algorithm(22): error C2374: 'std::pair': redefinition;
multiple initialization
14.0\VC\include\xmemory(18): note: see declaration of 'std::pair'
14.0\VC\include\algorithm(22): error C2059: syntax error: '<'
14.0\VC\include\algorithm(67): error C2143: syntax error: missing ';' before
14.0\VC\include\algorithm(67): error C2447: '{': missing function header
14.0\VC\include\algorithm(133): error C2988: unrecognizable template
14.0\VC\include\algorithm(133): error C2143: syntax error: missing ';'
before '<'
14.0\VC\include\algorithm(133): error C2433: 'iterator_traits': 'inline' not
permitted on data declarations
14.0\VC\include\algorithm(133): error C4430: missing type specifier - int
14.0\VC\include\algorithm(133): error C2059: syntax error: '<'
14.0\VC\include\algorithm(148): error C2143: syntax error: missing ';'
before '{'
14.0\VC\include\algorithm(148): error C2447: '{': missing function header
14.0\VC\include\algorithm(157): error C2988: unrecognizable template
14.0\VC\include\algorithm(157): error C2143: syntax error: missing ';'
before '<'
14.0\VC\include\algorithm(157): error C2433: 'pair': 'inline' not permitted
14.0\VC\include\algorithm(157): error C4430: missing type specifier - int
14.0\VC\include\algorithm(157): error C2374: 'std::pair': redefinition;
14.0\VC\include\algorithm(157): error C2059: syntax error: '<'
14.0\VC\include\algorithm(176): error C2143: syntax error: missing ';'
before '{'
14.0\VC\include\algorithm(176): error C2447: '{': missing function header
14.0\VC\include\algorithm(184): error C2988: unrecognizable template
14.0\VC\include\algorithm(184): error C2143: syntax error: missing ';'
before '<'
14.0\VC\include\algorithm(184): error C2433: 'pair': 'inline' not permitted
14.0\VC\include\algorithm(184): error C4430: missing type specifier - int
14.0\VC\include\algorithm(184): error C2374: 'std::pair': redefinition;
14.0\VC\include\algorithm(184): error C2059: syntax error: '<'
14.0\VC\include\algorithm(198): error C2143: syntax error: missing ';'
before '{'
14.0\VC\include\algorithm(198): error C2447: '{': missing function header
14.0\VC\include\algorithm(209): error C2988: unrecognizable template
14.0\VC\include\algorithm(209): error C2143: syntax error: missing ';'
before '<'
14.0\VC\include\algorithm(209): error C2433: 'pair': 'inline' not permitted
14.0\VC\include\algorithm(209): error C4430: missing type specifier - int
14.0\VC\include\algorithm(209): error C2374: 'std::pair': redefinition;
14.0\VC\include\algorithm(209): error C2059: syntax error: '<'
14.0\VC\include\algorithm(238): error C2143: syntax error: missing ';'
before '{'
14.0\VC\include\algorithm(238): error C2447: '{': missing function header
14.0\VC\include\algorithm(260): error C2988: unrecognizable template
14.0\VC\include\algorithm(260): error C2143: syntax error: missing ';'
before '<'
14.0\VC\include\algorithm(260): error C2433: 'pair': 'inline' not permitted
14.0\VC\include\algorithm(260): error C4430: missing type specifier - int
14.0\VC\include\algorithm(260): error C2374: 'std::pair': redefinition;
14.0\VC\include\algorithm(260): error C2059: syntax error: '<'
14.0\VC\include\algorithm(280): error C2143: syntax error: missing ';'
before '{'
14.0\VC\include\algorithm(280): error C2447: '{': missing function header
14.0\VC\include\algorithm(292): error C2988: unrecognizable template
14.0\VC\include\algorithm(292): error C2143: syntax error: missing ';'
before '<'
14.0\VC\include\algorithm(292): error C2433: 'pair': 'inline' not permitted
14.0\VC\include\algorithm(292): error C4430: missing type specifier - int
14.0\VC\include\algorithm(292): error C2374: 'std::pair': redefinition;
14.0\VC\include\algorithm(292): error C2059: syntax error: '<'
14.0\VC\include\algorithm(304): error C2143: syntax error: missing ';'
before '{'
14.0\VC\include\algorithm(304): error C2447: '{': missing function header
14.0\VC\include\algorithm(435): error C2988: unrecognizable template
14.0\VC\include\algorithm(435): error C2143: syntax error: missing ';'
before '<'
14.0\VC\include\algorithm(435): error C2433: 'pair': 'inline' not permitted
14.0\VC\include\algorithm(435): error C4430: missing type specifier - int
14.0\VC\include\algorithm(435): error C2374: 'std::pair': redefinition;
14.0\VC\include\algorithm(435): error C2059: syntax error: '<'
14.0\VC\include\algorithm(461): error C2143: syntax error: missing ';'
before '{'
14.0\VC\include\algorithm(461): error C2447: '{': missing function header
14.0\VC\include\algorithm(472): error C2988: unrecognizable template
14.0\VC\include\algorithm(472): error C2143: syntax error: missing ';'
before '<'
14.0\VC\include\algorithm(472): error C2433: 'pair': 'inline' not permitted
14.0\VC\include\algorithm(472): error C4430: missing type specifier - int
14.0\VC\include\algorithm(472): error C2374: 'std::pair': redefinition;
14.0\VC\include\algorithm(472): error C2059: syntax error: '<'
14.0\VC\include\algorithm(535): error C2143: syntax error: missing ';'
before '{'
14.0\VC\include\algorithm(535): error C2447: '{': missing function header
14.0\VC\include\algorithm(593): error C2061: syntax error: identifier
'forward_iterator_tag'
14.0\VC\include\algorithm(613): error C2061: syntax error: identifier
14.0\VC\include\algorithm(629): error C2995: '_FwdIt1
std::_Search_unchecked(_FwdIt1,_FwdIt1,_FwdIt2,_FwdIt2,_Pr &)': function
14.0\VC\include\algorithm(591): note: see declaration of
'std::_Search_unchecked'
14.0\VC\include\algorithm(662): error C2061: syntax error: identifier
14.0\VC\include\algorithm(693): error C2061: syntax error: identifier
14.0\VC\include\algorithm(693): fatal error C1003: error count exceeds 100;
stopping compilation
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
Thanks,
Majid
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-4-8-2-boost-1-6-2-msvc2015-error-running-empty-main-tp4662887.html
- [cgal-discuss] CGAL 4.8.2 boost 1.6.2 msvc2015 error running empty main(), majid, 08/07/2017
